Old 08-12-2009, 10:45 PM   #1
kylecoyote
Which lift kit 3/4 or 1/2 ton?
Thanks for any help to start off........Ok I am putting 76 3/4 ton axles under my 77 shortbed K10 so going from dana 44 front 12 bolt rear to dana 44 front 14 bolt rear. I have researched and it looks like I have to change my rear u bolts and plates when I swap the axles. I'll be going with a kit that includes rear springs with u bolts not blocks. So I was wondering do I order the kit for a half ton or three quarter ton truck, ride doesn't really matter to me? Also to anybody that has done this swap if you went with discs all the way around and converted the 14 bolt what do you have for a brake setup? As far as master cylinder and proportioning valve?
Original is the best
kylecoyote is offline   Reply With Quote
Old 08-12-2009, 11:28 PM   #2
Mudder
Mudder's Avatar
Re: Which lift kit 3/4 or 1/2 ton?
I don't think with most kits there is an option for 1/2, 3/4 ton springs. They are the same. I am running disks frt and back, using the old drum,drum master with a booster. I change pads regularly and have never had any trouble. I have blown the seal on the piston in the master a couple of times but never lost any braking. We are talking 13 yrs they have been on the truck. Oh and I used all the parts rotors, bearings, and backing plates from a dana 44 on my 14 bolt. They work great. Oh and I don't have a E brake. Bought some line locks at one time but never installed them.
The blocks are gone from the rear now. The truck rode better with the factory springs and 4" blocks than the springs I have back there now.
Mudder is offline   Reply With Quote
Old 08-13-2009, 05:54 AM   #3
Blazer1970
Blazer1970's Avatar
You would need the 3/4 ton kit. The only difference would be the rear u-bolts since the 14 bolt has bigger diameter tubes than a 10/12 bolt.
Blazer1970 is offline   Reply With Quote
Old 08-13-2009, 08:05 AM   #4
they all list the kits the same.But,tell them you need a K/20 application and you`ll be fine.
Old 08-13-2009, 03:52 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yep x2
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
