![]() Join Date: Feb 2009
Frame mount booster-m/c question...
OK guys, time to put your collective genius to some good use..
I know somewhere on here I have seen it done, but haven't been able to relocate that particular build. I want to use a frame mounted master cylinder/booster combo. My question is this: How do you operate it? Would you use the old hot rod type pedals that come up through the floor or set up some type of multiple lever contraption..? I also thought of building a cable operated lever setup? I am a bit skeptical of using a cable setup for fear of it failing under emergency STOMP load.. lol Any thoughts appreciated. This is the type I want to use. ![]()
1967 C10 LWB 454/TH400 1971 C10 SWB 1984 C30 LWB Dually 454/4 spd 4:10 2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison |
Re: Frame mount booster-m/c question...
Found it! Nevermind.. lol I guess I just wasted more space on the board...
![]() Join Date: Jun 2006
Post the link you found here for others.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
Those things are great for guys wanting to smooth their firewalls.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Here is a link to the unit produced by Scott's Hot Rods..
