Old 08-12-2009, 11:48 AM   #1
OrrieG
OrrieG's Avatar
HEI clearance in TF??
I have a knot in my stomach about clearance and am feeling lazy today so could someone post a photo of a TF with SBC and GM HEI installed with a stock firewall? I am ready to go to final paint on my firewall and if I need to modify it now is the time. My cab is off and it looks like it will clear but want to be sure.
Thanks a bunch Patrick
Old 08-12-2009, 03:03 PM   #2
jjjmm56
jjjmm56's Avatar
Re: HEI clearance in TF??
I don't have the pics but I"m running a camaro sub and have no problem with my HEI dis. I have removed and installed it many times with no issues
jjjmm56 is offline   Reply With Quote
Old 08-12-2009, 06:36 PM   #3
OrrieG
OrrieG's Avatar
What is your clearance from driver back of head to firewall? I think the Camaro clips move the engine a little forward, I'm running the stock frame with engine in stock location with front mounts. Thanks Patrick
Old 08-13-2009, 10:53 AM   #4
OrrieG
OrrieG's Avatar
I think I am ok. The back of the HEI sticks out 2.75" from the back of the driver side head. The firewall recess is 4" deep. From my pictures and memory I have about 1" between the head and firewall so in theory I should have minimum 1.25", probably more clearance. If not I will get out the porta-power and move the firewall a little bit.
Old 08-13-2009, 04:51 PM   #5
jjjmm56
jjjmm56's Avatar
I can't give you a measurment, my motor is out of the truck now but you should be ok
Old 08-13-2009, 07:35 PM   #6
OrrieG
OrrieG's Avatar
Thanks all for what you could give me. I'll find out when the cab goes back on.
Old 08-13-2009, 07:51 PM   #7
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Orrie, I have mine installed on a Camaro clip. But I do believe that if your valve covers clear the firewall, then the HEI will have plenty of room due to the large indention (sp)!!!!
ChuckDriver is offline   Reply With Quote
Old 08-13-2009, 11:07 PM   #8
OrrieG
OrrieG's Avatar
Thanks Chuck your head clearance looks about like mine, so all should be well.
Old 08-17-2009, 12:09 PM   #9
chris71
chris71's Avatar
looks like you will be fine, but if you end up having clearance issues, a trick is to install the dist. without the cap, and then install the cap after the dist is already in the motor. also, some of the big dist. companies make small diameter hei's IIRC.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
