Old 04-04-2003, 08:16 AM   #1
HEAVY CHEVY
BOWTIE FOREVER
HEAVY CHEVY's Avatar
Question Headlights & Dash Problems
Thanx in advance for all of the help.
My problems are
1.When my headlights are on dim the high beam indicator light is on and when in high it's out.
2.All of my dash lihjts are out.
3.Also,as you would've figured my fuel gauge is off big time.
I tried to fix with a new headlight switch a new dimmer switch and checked the ground on the back of bezel.
So as you can tell I'm very confused at this moment.
Again THANX for everyones help.
LARRY
69 C-10 SHORT FLEET BED
350 4-BOLT/400 turbo
upper & lower molding
65 IMPALA 2-DR
283/POWERGLIDE
66 IMPALA 2-DR
hopefully 283/350
~ CAMELTOE ROCKS ~
HEAVY CHEVY is offline   Reply With Quote
Old 04-04-2003, 08:26 AM   #2
tom hand
CCRider
tom hand's Avatar
How did you check your ground?....cause it sounds as if your dash is not grounded. I had similar problems and it was the ground. On my 72 the ground was a cheesy clip that was just clipped on the metal on the dash. I cut it off and replaced it with a ring terminal and a machine screw...no more problems
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 04-04-2003, 08:46 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Make sure you have a good ground for the headlights on the top passenger side of core support. Take that bolt out and sand it real good. That fixed mine.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-04-2003, 03:54 PM   #4
Liz
Catchy title goes here..
Liz's Avatar
Thanks for the ideas so far guys. He had checked the ground last night , it was a good. Someone else suggested that maybe from sitting a mouse or something gnawed on a wire in the dash and its shorting out. (the truck sat for about 3 years before he started working on it again) He is at the swap meet in Charlotte or he would reply himself ( and Im home with the kids jealous )
Liz is offline   Reply With Quote
