Old 08-14-2009, 04:30 PM   #26
domsan
domsan's Avatar
Re: domsan c10 custom
the gas tank for auto gas LPG
the frame ready to paint
domsan is offline   Reply With Quote
Old 08-14-2009, 04:36 PM   #27
domsan
domsan's Avatar
The first parts in color
Old 08-14-2009, 11:06 PM   #28
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Man that is looking great. You are sure working fast... much faster then I am.
Keep up the great work and can't wait to see it finished.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-15-2009, 12:33 AM   #29
OARNGESI
OARNGESI's Avatar
Really nice job so far
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 08-15-2009, 01:08 AM   #30
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Are you going to run LPG only or start it on gas & the switch to LPG ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 08-15-2009, 02:13 AM   #31
domsan
domsan's Avatar
no, I drive both. gas and lpg. for a further away, I use other gas and lpg
in our gasoline is very expensive, and if the truck as daily use them is a good way
Old 08-15-2009, 06:40 PM   #32
domsan
domsan's Avatar
the rear axle in paint and with airride
Old 08-15-2009, 06:44 PM   #33
domsan
domsan's Avatar
the front axle in paint and with airride
and the first time again since a long time with the cab
Old 08-15-2009, 07:20 PM   #34
threeonthetree
threeonthetree's Avatar
looks great!
i really need to paint the rear end components on my truck.
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 08-15-2009, 11:30 PM   #35
ERASER5
ERASER5's Avatar
Looking at the flag, I would have guessed you were from SOUTH Germany!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-15-2009, 11:54 PM   #36
mcbassin
Still Learning
mcbassin's Avatar
I was thinking the same thing.....there are a bunch of those flags flying here in Oklahoma too.
Domsan,
You are flying on this build. I can only imagine how many parts you can find for a 72 Chevy in Europe. Keep up the fine work!
Old 08-16-2009, 02:30 PM   #37
domsan
domsan's Avatar
Originally Posted by threeonthetree View Post
looks great!
thanks !
Hello! I like the southern United States.
i live in Germany, North Rhine-Westphalia
therefore the flaage !
Domsan,
Hello!
parts here in germany learn you can forget
Most parts we manufacture ourselves, or I do a buy in the Staates
I'm always where I also share by private people in the usa can buy and I also agree then send germany
but also over the last year in the United States a few people know
Old 08-17-2009, 04:45 PM   #38
domsan
domsan's Avatar
the bed
the steering
the new brake
Old 08-17-2009, 04:51 PM   #39
domsan
domsan's Avatar
the lpg tank
the door`s
the doors would be in an acid bath and then removed once painted immersion
Old 08-17-2009, 10:33 PM   #40
eagleuh1
eagleuh1's Avatar
Your one damn skilled redneck. Excellent build. I like the fact you still do all this after halving to build most of your own sheetmetal. Most people would of sold it on ebay or CL by now. Can't wait to see it done. What kind of milage(Kmage) can you get out of that size tank. Thanks again for keeping some American steel on the road.
eagleuh1 is offline   Reply With Quote
Old 08-19-2009, 11:23 AM   #41
domsan
domsan's Avatar
thanks !
I have the truck on ebay germany yes bought! I immediately took the truck well as daily driver!
The condition was I do not care, I like this work because it is then sometimes called to work
I've had worse projekte
my 34 chevy truck, which was worse
to time, I have it only once because dan 72 left
once the 72 chevy is finished I will be back in the 34 chevy go off
times here are pictures of my 34 where I had picked him
as you see has not much of this vehicle confessed, and had also bought a grille, but then I came to the idea of rebuilding the truck. than 50 'hot rod truck
time to put about 3 years working in it
on the lpg tank
come 94 liters / 24 gal gas inside and has a range of 600 km / 372 miles
Old 08-19-2009, 04:45 PM   #42
domsan
domsan's Avatar
first paint the cab
Old 08-20-2009, 01:06 PM   #43
domsan
domsan's Avatar
the new engine !
the engine is 350 chevy sb .030 over ,
edit crankshaft and pleule ,
trick flow cylinder head`s
edelbrock camshaft and bridge
and other changes . in the engine, I have a lot of work put inside
the motor in the frame with gear
the exhaust, a complete stainless steel plant with magna flow muffler
Old 08-21-2009, 03:06 PM   #44
domsan
domsan's Avatar
the cab on the frame
Old 08-21-2009, 03:21 PM   #45
mcbassin
Still Learning
mcbassin's Avatar
LOOKS GOOD! Man, you are moving fast!
Old 08-21-2009, 10:16 PM   #46
VA72C10
VA72C10
VA72C10's Avatar
Great work! Looking good. I'll be interested to see how low the rear sits with the bed on. I like the fact that with those cups you don't have to drill for airline in the frame. But I'm guessing the cups won't let you get nearly as low as without them...
Old 08-22-2009, 01:54 AM   #47
domsan
domsan's Avatar
Thank you!
for time is about 1 year working there in the truck
We are in the end, if everything works out of the truck is ready next month
I did not want to make extreme frame work, the depth of the truck is ok for me. I am sure the truck would also lay on the ground, but unfortunately this makes here in germany the street with no
Old 08-22-2009, 01:56 AM   #48
domsan
domsan's Avatar
Preparation for paint
Old 08-22-2009, 09:37 AM   #49
eagleuh1
eagleuh1's Avatar
Damn, guess we'll have to wait for a color shot. Time for a commercial. Who makes that fuel tank? and what kind of carb do you use to run on both gas and LPG? Thanks. Jim.
Old 08-22-2009, 10:22 AM   #50
nuke1
nuke1's Avatar
great looking trucks you have there, good job.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
