Old 08-12-2009, 09:27 PM   #1
ChiefThinElk
ChiefThinElk's Avatar
Primer or Seam Sealer First
Removing paint with 80 grit sand paper and plastic paint remover attached to high speed. When I get ready to shoot primer do I seam seal the cab top before or after the primer? What is your experience and did it work okay? Thank you in advance.
ChiefThinElk is offline   Reply With Quote
Old 08-12-2009, 09:31 PM   #2
Re: Primer or Seam Sealer First
Prime first,seal,and prime.
Old 08-12-2009, 10:47 PM   #3
Rokcrln
Rokcrln's Avatar
What I have always done and it has worked out really well for me and others is do all your body work so you are ready for paint then do your seam sealer and spray your paint. You want the surface prepped the same for sealer as you do for paint. But also keep in mind anything is better now a days then what the factory had be then!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 08-13-2009, 01:55 AM   #4
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Kevin
LFD Inc.
I agree... We did mine in the paint booth just before spraying it.
It's almost like caulking before you paint a house... It's applied just before you paint. The way we applied mine is similar to caulking a house - Apply a bead and smooth it out with your finger. Instead of water on your finger, use some reducer and have plenty of rags handy to wipe of the excess. It's a little hard on the fingers but worth it if you want a nice smooth bead.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 08-13-2009, 05:00 AM   #5
Just make sure it`s cured before painting.i`ve seem paint crack when coated too soon.but,the main thing is you shouldn`t apply ahead of priming.I use high-build primer,sand,then shoot tech primer.I usually seal between primers.
Old 08-13-2009, 06:33 PM   #6
ChiefThinElk
Thank you all.
Old 08-13-2009, 06:58 PM   #7
mbgmike
Our you can do it like the factory and just slop it on then wipe the excess in an area no will ever see for a while
mbgmike is offline   Reply With Quote
Old 08-13-2009, 10:10 PM   #8
big blue 72
or let it drizzle down the inside of the door pillar
Broken Back Club
72 Club
GMC Club
Panel truck Club
6 cylinder Club
Unfinished Projects Club
Outdoor Sportsmens Club
big blue 72 is online now   Reply With Quote
Old 08-14-2009, 08:03 PM   #9
ChiefThinElk
I'm still removing the paint, never realized how difficult and tedious the job really is but I got all the sealer off the roof drip edge. I was real lucky very little rust. Learning to be real patient.
Old 08-14-2009, 08:08 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Paint always seems to not want to come off unless its rusty paint... Btw I always seal everything 1st them move on from there...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-14-2009, 08:46 PM   #11
BCOWANWHEELS
I thimk i,am gonna put some epoxy paint on my drip rail before i put the seam sealer on. I used a coarse wire brush in my die grinder to clean everything up.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-14-2009, 10:32 PM   #12
jaymc32
What do you use as a seam sealer? I mean is it a specific product or something I can pick up at the hardware store. I ask cause I'm gettin' ready to clean up the drip rails on my truck and hadn't realized there was even such a thing as seam sealer.
jaymc32 is offline   Reply With Quote
Old 08-14-2009, 11:42 PM   #13
dan42
dan42's Avatar
Go to your local body shop supply store - 3M has a couple of products that will work good.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-15-2009, 11:41 AM   #14
mbgmike
Thats what we do. sand blast then Epoxy then sealer
Old 08-15-2009, 04:43 PM   #15
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
I just sand blasted mine then epoxy primer. The seam sealer will go on next then the paint.
Jason
jay_shy is offline   Reply With Quote
Old 08-15-2009, 11:31 PM   #16
BCOWANWHEELS
Dont use nothing but 3m seam sealer cauz its the best made. It costs twice as much too. Like 18-22 bucks a tube
Old 08-17-2009, 12:54 AM   #17
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
Use nothing but 3m 8307 automix...I used a couple products beforehand and found myself redoing it twice before finally getting this product...One tube and gun rental from my local bodyshop ran $45 and the finish is stellar...I learned my lesson so you don't have to! Vertical sections will be bumpy and need a good bit of sanding but he horizontal areas are dead level and flawless...
Beatcoaster is offline   Reply With Quote
