Old 08-15-2009, 08:31 AM   #1
mickeymouse
Mix and Match - 68 Chevy fenders and hood with a 71 GMC Grill
I've searched, I read that you can use 68 Chevy Fenders with the later GMC stuff.
Can you use 68 fenders and hood with a later GMC grill?
mickeymouse is offline   Reply With Quote
Old 08-15-2009, 08:39 AM   #2
msgross
msgross's Avatar
Re: Mix and Match - 68 Chevy fenders and hood with a 71 GMC Grill
good question, I would talk to rokcrln since I have seen him modify a few hoods to fit on newer trucks.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-15-2009, 09:28 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There's 2 answers... both yes and no.
For a nuts and bolts simple job, I say no. The fenders WILL work, they are the same. The hood though, you'll need a 67-68 grill top bar. You have to drill the rivits that hold the top bar to the grill and then install the 67/68 unit. Then, you'll need a 67/68 hood latch assembly. Then it'll work.
Old 08-16-2009, 08:10 AM   #4
mickeymouse
Doesn't sound too tough.
Thanks for the info.
Old 08-16-2009, 08:41 AM   #5
For a nuts and bolts simple job, I say no. The fenders WILL work, they are the same. The hood though, you'll need a 67-68 GMC grill top bar. You have to drill the rivits that hold the top bar to the grill and then install the 67/68 unit. Then, you'll need a 67/68 GMC hood latch assembly. Then it'll work.
I hope you don`t mind,Andy.I inserted GMC just to be "sure" it was fully understood.Prolly not necessary.That 67/68 GMC top bar is a bit hard to find and not reproduced.That`s what makes it a bit harder.
Old 08-16-2009, 08:57 AM   #6
mickeymouse
This will be interesting then. I better start hunting one down.
Old 08-16-2009, 10:33 AM   #7
Longhorn Man
thanks Tim... good addition, keeps the confusion down.
Old 08-16-2009, 02:00 PM   #8
Well,I`m not trying to be a nazi(and you know that).Mickey said it would be easy so I wanted to be sure it was.Cuz,simple can end up hard by taking the long road.
heyMickey.just watch for guys swapping 67/68 (GMCs) to Chevys.The disease isn`t that rare.
Old 08-16-2009, 03:13 PM   #9
Ben IV
I did this to my 69 gmc, all i changed was the grill top bar and the hood. Is a 67-68 gmc hood latch different from 69-72? I dident change mine, had to run the plunger way out though. I scored the top bar from a board member.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 08-16-2009, 04:37 PM   #10
mickeymouse
Do you have any pictures of the top bar?
I may actually have one.
Old 08-16-2009, 05:33 PM   #11
Longhorn Man
you chainged a 69 GMC into a 68 chevy without swapping the grill or core support?
Old 08-16-2009, 05:47 PM   #12
mickeymouse
I think he kept it GMC... which is what I want to do, too. Just want the 68 Chevy hood.
Old 08-16-2009, 08:15 PM   #13
Ben IV
Exactly, I dont have a pic of mine but heres one i found online. You take your grill and fender moldings off drill out the rivits for the chrome top bar and rivit on the steel top bar.
69 GMC panel truck
Old 08-16-2009, 08:32 PM   #14
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Or, for a lower profile on the '69-72 hood, you could pie-cut it. Seems like the most you can take out on the front end is 1.5 inches, and that is to keep it from contacting the top of the radiator support.
Member Nr. 2770
Old 08-16-2009, 08:41 PM   #15
Ben IV
True or another option would be to cut off the leading edge of a 67-68 Hood, I really like the look on 69-72 chevys but on a gmc you might as well just change the grill top bar since thats all that needs changed to run the early hood.
69 GMC panel truck
Old 08-17-2009, 06:05 AM   #16
Yes.If you look at the front it is slopped like the hoods and the later ones are steeper,like the hoods.But,your`s works fine?I`ve wondered if it really mattered.
Old 08-17-2009, 08:13 AM   #17
mickeymouse
That's what I am going to do. I can't weld sheet metal all that well.
Old 08-17-2009, 07:15 PM   #18
Ben IV
Hmm guess i should pick one up, It works but could be better, plus the plunger is ran almost all the way out. Thanks for the info.
69 GMC panel truck
Old 08-17-2009, 09:32 PM   #19
mickeymouse
Hmn, will a 67-8 Chevy latch work?
