Old 08-17-2009, 11:52 PM   #1
PBFAB.COM
PBFAB.COM's Avatar
2" Drop Trailing arms
Well, I finally have the tubular dropped trailing arms the way I want them, and figured I would post up some "spy pics". I won't be officially releasing them for another week or so. These are for a board member's blazer project.
They are 2" DOM tubing with a 2" drop built in. They will be compatible with either coil-springs or an airbag. The front joint is a polyurethane flex joint (rebuildable and greasable). They are compatible with factory, factory replacement, or Porterbuilt trailing arm crossmember. I have a few tricks up my sleeve for the Porterbuilt trailing arm x-member and will be running a special on the set-up.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
