Need some input on control arms. .
So heres how the story goes. .
I got myself a 67, stock floor body drop, full frame from the front clip back with one hell of a Z. all i need to finish up the front is a set of control arms. Im Leaning towards ART but ive heard the bushings tend to wear and crack kinda quick so ive been researching some other options but im still not sure what application to go with. Im going with at least a 22inch wheel with 3 inch drop spindles so stock arms are out of the question. Lemme know what you guys think or if you have any other suggestions. Thanks in advance!!
67 c10 Stockfloor Bodydrop Last edited by 454inthehood; 08-17-2009 at 04:30 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Need some input on control arms. .
You have a couple choices and both companies have members here.
Contact Nathan Porter (member Porterbuilt) of Porterbuilt Street Rods. www.dropmember.com. Look here at just some of his products: http://67-72chevytrucks.com/vboard/s...d.php?t=351264. Another member is Thorbecke Bros of www.*****************. Check out Jason's products here: http://67-72chevytrucks.com/vboard/s...ight=Thorbecke.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-17-2009 at 05:02 PM. |
#3 | |
Porterbuilt arms would be my first choice, ART second, & SD third.
Señor Member
I've had a set on my truck that were from ART's first production run. I am unaware of any cracks, and I don't believe the bushings are worn.
I am curious why SD is the third choice. I bought some and after seeing a set. I thought they were very well built and they were a good bit cheaper than ART. I am new to these types of suspension parts so any info would be appreciated.
I believe they're the heaviest.
We've used the ART arms for several years with good success, and never had any issues with the bushings wearing excessively. We have since began building our own arms. The main difference between our arms and the others, are the machined Delrin bushings we use. I decided to use delrin for a few reasons: less deflection than rubber impregnated or polyurethane bushings; self-lubricating (don't get the squeak noise); simple and easy installation (no press required to assemble or disassemble).
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
awsome thanks for the input guys, im leaning towards porterbuilt now forsure, they only come in raw finish correct? and bolt directly to a stock crossmember if im not mistaken?
67 c10 Stockfloor Bodydrop |
#9 | |
It'd be alot cooler if you did
Not having to use a press to change bushings would be awesome. Those things are really in there!
454inthe hood,... go Porterbuilt,... you won't regret it.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-18-2009 at 06:13 PM. |
thanks lolife, yea thats what ive decided on quality seems second to none
big guy
![]() Join Date: Jun 2008
i can't say how the others are but i can tell you about Nathan at porter built He has been great to work with, and is always willing to help! I have a set of his arms and i really like them so far.
good luck your your project Ray |
