08-15-2009, 07:13 PM | #1 |
Finally got them now how...
I finally got the wheels that I have been looking for-- BUT they are painted.. painted aluminum rims-- 15x10's- how can I effectively remove the paint and not harm the wheels?? muratic acid wash them??? any experience here would be GREATLY appreciated-- oh and after the paint is removed, I will polish them .
2003 2500 HD Crew Cab 1965 GMC K10 1972 Chevrolet k5 blazer |
08-15-2009, 07:25 PM | #2 |
Re: Finally got them now how...
go to home depot or lowes and hardware store should have "paint striper" just follow directions carefully on the can you have to let it sit on for awilre and it will get all mooshy and you just scrap it off they have other kinds depending on the type of paint but heres a fairly cheap one
http://www.homedepot.com/webapp/wcs/...3+90401+500468 |
08-15-2009, 08:38 PM | #3 | |
08-15-2009, 08:39 PM | #4 |
You can have them media (plastic beads) blasted. It'll ONLY remove the paint & leave the rims ready for a nice polish.
I also think soda blasting will do the trick. It's also very enviormentally friendly. Ratty 46 |
08-15-2009, 08:47 PM | #5 |
it shouldnt but you should check around youll have to ask them
08-15-2009, 08:51 PM | #6 |
I did a set once and I think I found some stripper that said it was safe for use on aluminum
08-15-2009, 09:33 PM | #7 |
I have heard that aircraft stripper will work on alum, and not harm it. Several third generation camaro owners use it to paint their alum wheels.
08-16-2009, 01:04 AM | #8 |
In the Forgotten far North.
Brake fluid makes a great paint remover as well.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
08-16-2009, 07:18 AM | #9 |
Another vote for soda blasting.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
08-16-2009, 09:45 AM | #10 |
i have used aircraft aluminum stripper in the past but the stuff is a major mess and pain in the rear to get in all the small spots. ive done about 4 sets this way and it doesnt harm the aluminum but this last time on my slots i used the sand blaster w/ some 30 grit sand and it worked awesome but i have ALOT of sanding and polishing ahead of me to get the pitting from the sand out.
so the moral of my story is to media blast them with some real fine media from eastwoods so it doesnt pit the finish too bad and they should be ready for some polishing without the sanding part. good luck and post some pics of them before and after.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
08-16-2009, 10:12 AM | #11 |
use oven cleaner,i found some old keystone mags that had been painted a while back that had paint all over them.it took it right off. what ever you use ,do the back first to be sure it doesn't ruin your rims.
08-16-2009, 04:10 PM | #12 |
Just use a rag and some good o acetone and bam its done. Its just gonna take some elbow grease. It works great.
Its Kool to be a square 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers New Mexico Member --- Member of the Square Body Club--- |
08-16-2009, 04:33 PM | #13 |
I just finished stripping the clear coat off some factory rims using aircraft aerosol paint remover. This is the 4th set of rims I've done and it's messy but works well. I haven't had any issues with it affecting the aluminum.
08-16-2009, 07:33 PM | #14 |
aircraft coating remover works but it is a mess you might have to brush it off to get it out of any small crevices but it shouldn't hurt em.
08-16-2009, 09:52 PM | #15 |
Jonny
I also recommend aircraft remover, it won't harm aluminum because guess what aircraft are made of....ALUMINUM!
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
08-16-2009, 10:39 PM | #16 |
I have car A.D.D.
I am glad I was not going to have to be the one to break this news! I agree, use Bulldog brand. It works great every time. I have had the cheap stuff work good one can and poorly the next. Take your time, have a lot of water to rinse with and do it in a very well ventilated area. I like to wear a mask and you need gloves when using it.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
08-17-2009, 08:48 PM | #17 |
ok- I used the airplane paint remover in aerosal-- it is water solvent-- after testing in a small area-- I then proceeded to the car wash-- sprayed on-- waited a minute or two and washed off===it took 95% of all of the paint off of the wheels!!!! THANKS GUYS
08-17-2009, 09:07 PM | #18 |
Happy to be here
Cool! And they look great on there. Very retro...
08-17-2009, 10:37 PM | #19 |
wow- nice wheels
08-17-2009, 10:42 PM | #20 |
Western Bullets . I love that wheel . I used to have a magazine article with a stepside running those wheels . It was perfect . They look great on your truck .
Frank
Born and proudly residing in a Red State ! |
08-19-2009, 08:20 PM | #21 |
Thanks-- I will have more pictures coming-- I put ventshades the stainless ones on it and diamond plate Dee Zee running boards!!! can we say it looks like the year ... 1979!!
08-19-2009, 11:52 PM | #22 |
Happy to be here
All you need is a chrome roll bar with a set of KC dayliters...
