Old 04-05-2003, 07:49 PM   #1
72gmcshorty
72gmcshorty's Avatar
Question Whats the proper polishing procedure
I bought a buffing wheel and some polishing creme. Whats the proper way to apply and do this onto my grill? Do i just apply the creme with a rag, left it haze, and then buff it off?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 04-05-2003, 08:56 PM   #2
69 Short Fleet
What type of "polishing cream" did you buy, is it in a toothpaste tube or ??? and what is the "brand name"??? Doug
69 Short Fleet is offline   Reply With Quote
Old 04-05-2003, 09:04 PM   #3
72gmcshorty
Meguiar's Medium Cut Cleaner
Meguiar's Foam Polishing Pad
1992 Gmc 2wd
Old 04-06-2003, 03:21 AM   #4
69 Short Fleet
Hmmm, I've never used Meguiar's before so I'm not sure about that one. Are the GMC grills aluminum also? Doug
Old 04-06-2003, 04:20 AM   #5
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Any rubbing/polishing compound I've ever used, it works best if you put the compound on the wheel, squirt the area to be polished with a squirt bottle of water and buff at a slow speed, adding water as needed.......the water does most of the work for you and without it, you bake the compound and it's a bear to get off and leaves blotches in your finish. If it's pitted very bad, you're in for a long haul. I spent about 12 hours polishing a set of fuel tanks for my Peterbilt when I painted it.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
