Old 08-18-2009, 09:27 PM   #1
DuramaxC10
oppions needed
i want to build a 67-72 4x4 truck
What would be cheaper buy a 2wd truck and put it on a 4x4 chassis
0r keep looking for a complete 4x4 truck
1968 Chevy C10 6/8 drop ( great grandpas truck) under construction
1972 Ford Bronco project
2006 chevy Silverado 2500hd dd
1995 k2500 solid axles 12v cummins crew cab
DuramaxC10 is offline   Reply With Quote
Old 08-18-2009, 09:38 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: oppions needed
depending on how much work you want to do... if you are a fab man, then all you need is a body.
But if you are the average dude, hold out for a truck with 4X4 under it already.
Old 08-18-2009, 10:41 PM   #3
big_al_71
big_al_71's Avatar
Re: oppions needed
find a 4x4 to begin with
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-18-2009, 10:48 PM   #4
dan42
dan42's Avatar
Re: oppions needed
X2. I just passed one up for $900. You can find them.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-18-2009, 11:11 PM   #5
NUTS4TRUCKS
NUTS4TRUCKS's Avatar
Re: oppions needed
start with a 4x4 truck trust me ..
if you start with a 2wd truck and buy the 4x4 parts you'll probably have more in it than if you started with a 4x4 to begin with the you still have to make it all work
NUTS4TRUCKS is offline   Reply With Quote
Old 08-19-2009, 05:25 AM   #6
Re: oppions needed
I guess it all depends on what the truck or trucks cost.Most body swaps are done because they found a 4wd with a poor body for cheap then found a 2wd with a nice body.I don`t think these swaps would have happened if the prices were high on either truck.It was done because it was cheaper than buying a real nice 4wd.I think it all starts with finding the perect match or you are best to find a 4wd.It`s definately less work.
Old 08-19-2009, 02:25 PM   #7
mclairmo
Re: oppions needed
Buy a factory 4x4.
mclairmo is offline   Reply With Quote
Old 08-19-2009, 02:30 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: oppions needed
I agree...... Buy a factory 4x4 money ahead..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-19-2009, 03:24 PM   #9
rwolf9653
more ideas than money
rwolf9653's Avatar
Re: oppions needed
As someone who builds off road only vehicles, just buy a 4x4. There are just so many things like trans tunnel, extra crossmembers, proper axle alignment, steering geometry, changing the trans from 2wd to 4wd, tranfercase, shifter location/fabrication, etc. It is alot of work to do to compensate for a slight difference in purchase price.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 08-19-2009, 07:25 PM   #10
Re: oppions needed
I think he`s talking about putting a 2wd body on a 4wd frame.As long as the 2wd has a high hump it`s a straight swap.If a low hump 2wd,it`s no problem using the one ftom the 4wd donor.
Old 08-19-2009, 07:57 PM   #11
howard_m18
howard_m18's Avatar
Re: oppions needed
There are a couple of 67 4x4 on craigslist? PostingID: 1328118665 & 1311402696.
1967 C10 LWB, painted 2010 MUSTANG GRABBER BLUE & finally got it on the road after sitting in garage for 10+ yrs. Howard in MI.
howard_m18 is offline   Reply With Quote
Old 08-19-2009, 10:42 PM   #12
DuramaxC10
Re: oppions needed
could you send the links
Old 08-20-2009, 03:58 PM   #13
howard_m18
howard_m18's Avatar
Re: oppions needed
Here is the link to "craigslist" through out the USA. Just type in the post # in the search box.
http://www.searchallcraigs.com/resul...sa=Search#2609
Howard
