Old 08-20-2009, 05:18 PM   #26
SeventyOne
Re: 383
Ok so I got everything off except the parking brake assembly/cable and I can't for the life of me figure out how to get it out - there are two bolts holding the pedal assembly to the firewall, and the cable which travels through the firewall also. Took the nuts off the two bolts and it look like it needs to pull out towards the rear of the truck but I just can't get it....any advice?
SeventyOne is offline   Reply With Quote
Old 08-20-2009, 07:31 PM   #27
VA72C10
VA72C10
VA72C10's Avatar
Re: 383
You have to spread the bracket that holds the "ball" at the end of the cable. That will allow the cable to slide out and you can get it off. It took me a lil bit to figure that out when I was taking the cab off my truck.
Old 08-20-2009, 07:32 PM   #28
VA72C10
VA72C10
VA72C10's Avatar
Re: 383
To spread the bracket just put two screwdrivers in and pry in opposite directions and it'll open up. I then bent it slightly closed to hold it to the cable so I wouldn't lose it
