Old 08-21-2009, 05:38 PM   #8
kizer
Its Deja Vu time again
kizer's Avatar
Re: to Hydroboost, or vacuum boost? That is the question....
If I had my way I'd go Hydroboost all the way.
Vacuum boosters put out between 1,000-1,600 lbs of pressure to your brake system. The hydroboost puts out between 2,400-3000 lbs of pressure to your brake system. This is basically giving you the power to stop the vehicle. It's the actual clamping pressure your calipers or wheel cylinders have to clinch onto the rotor/drum.
Its on a Jeep, but the installation couldn't be much different for these old trucks.
http://www.stu-offroad.com/suspensio...droboost-1.htm
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
Last edited by kizer; 08-21-2009 at 05:41 PM. Reason: Removed link directly to a store. Looked kinda tacky and didn't want to look like a salesman.
kizer is offline   Reply With Quote
