Old 08-20-2009, 08:31 PM   #676
Strodder
Daring to be Different
Strodder's Avatar
Re: 1965/73 Cheap Build Up
Why are you stuttering?
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 08-20-2009, 08:35 PM   #677
Strodder
Strodder's Avatar
Originally Posted by Alan's Classic View Post
Trial and error. I personnaly like the original plan.
Thanks, I had to at least try a few ideas. The other side will be a lot easier. I hope.
And by the way thanks everybody for helping me make this decision.
Just slap me next time I do anything dumb.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-21-2009, 12:33 PM   #678
hessian18
Gen III Power
hessian18's Avatar
Looking good !! I lke the final choice on the drip rail.
When welding up the holes in the door, did you use a back filler piece ? Or just slowly fill the holes ?
I want to fill all the trim holes in my truck and cab, but im scared LOL !!
Looking foward to more pictures.
Gotta love being at work and posting on the net !! LOL Down here at the Pawnshop-shop..shop...LOL
---Bob---
'81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon...
hessian18 is offline   Reply With Quote
Old 08-21-2009, 03:02 PM   #679
Strodder
Strodder's Avatar
Originally Posted by hessian18 View Post
Looking good !! I like the final choice on the drip rail.
I usually weld up the small holes. The bigger one I use a brass tool that's made to hold behind the hole, if you can get at it. It works great. Just be patent. You have to weld a little at a time & let it cool so you won't warp the panel.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-21-2009, 03:03 PM   #680
Strodder
Strodder's Avatar
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-21-2009, 03:18 PM   #681
70 Suburban
Rods
I use copper pipe. Smash it with a hammer and weld on that. Works great
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 08-22-2009, 07:27 PM   #682
Strodder
Strodder's Avatar
Got some drip rail shaving done today. Welded across the back end of the cab. I also shaved the seams in the door jams. Plus the lower windshield seam. It probably won't show, but I shaved it just in case. I'm just a shaving fool.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-22-2009, 08:23 PM   #683
daverod
SSN 706
daverod's Avatar
Looks good. You worked on your steering linkage yet?
daverod is offline   Reply With Quote
Old 08-22-2009, 09:30 PM   #684
Strodder
Strodder's Avatar
Yes a long time ago. All I had left to do was install the steering shaft. It steers, just doesn't drive yet.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-23-2009, 03:28 PM   #685
watahyahknow
watahyahknow's Avatar
[QUOTE=Strodder;3478892]Got some drip rail shaving done today. Welded across the back end of the cab. I also shaved the seams in the door jams. Plus the lower windshield seam. It probably won't show, but I shaved it just in case. I'm just a shaving fool.
QUOTE]
maybe you should change youre screenname to gillette or wilkinson and eeeeeh be careful around the family jewels
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 08-23-2009, 05:30 PM   #686
Strodder
Strodder's Avatar
[quote=watahyahknow;3479979]
QUOTE]
I'll never change my screen name. Strodder means Street Rodder. If you read between the lines it says Gillette.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-30-2009, 08:27 PM   #687
Strodder
Strodder's Avatar
Got work on the bed today. This is how I got the bed. The guy cut the top of the rail to make it flip up. He then drilled a hole in the top of the fender to fill it with gas. Cool idea, but I didn't like it, besides It wouldn't work with the gas tank that I'm putting in between the rear of the frame. Next I gave to remove the fender to fill the hole. I already started to take the fill tube out.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-30-2009, 08:31 PM   #688
Strodder
Strodder's Avatar
Next I shaved the original gas fill hole.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-30-2009, 08:40 PM   #689
Strodder
Strodder's Avatar
The 73 bed had side running lights. They had to go. So here's how I did it. First cut a cardboard to fit the hole (the same as I did with the gas fill hole) Then transfer that shape to metal and trim it to fit perfect. Then be patient and tack it in a little at a time so you don't heat the panel too much and warp it. I also welded up all the little holes that were drilled on the top of the bed rails for tonneau cover and other stupid things he bolted to the bed.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-30-2009, 08:47 PM   #690
Strodder
Strodder's Avatar
Who ever did the body work on the cab was an idiot. He dented in the side trim holes, and filled them with bondo. First I ground out the bondo, then I hammered them back to shape as best I could. Now I have to finish the rest of the holes. In the bottom corner I had to make a patch panel to repair a small amount of rust. Doesn't look good in the picture, but actually doesn't look to bad in person.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-30-2009, 09:06 PM   #691
I like how the lines of the 73-87 style step bed looks on the 60-66. I would not have thought it would have blended in that well. IT didn't on my 70, but that looks really good on yours.
Old 08-30-2009, 09:23 PM   #692
Strodder
Strodder's Avatar
Thanks. I though so too. I've always liked the look of those beds best of all. It just so happens that it looks really good on my year. I got lucky when I found it, and at a great price.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-30-2009, 09:57 PM   #693
jason65
Registerd User
jason65's Avatar
Very Nice Dennis. I hope to be that good soon.
jason65 is offline   Reply With Quote
Old 08-30-2009, 10:07 PM   #694
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I agree it looks sharp.
Dennis either you need to slow down or I need to speed up. Nice progress and work. Stuff like this is what motivates others.
Alan's Classic is offline   Reply With Quote
Old 08-30-2009, 10:38 PM   #695
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
When you get done with this truck I have one you can work on!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 08-30-2009, 10:56 PM   #696
Strodder
Strodder's Avatar
Thanks guys. I can't slow down. If I do it will be stop mode. I want to get this project on the road ASAP, but can't get time on my own lift. That's why I doing the body work on the one side. After this side I am going to turn it around and do the drivers side. At least I'm getting something done on it.
After the Studebaker I have a Jeep to move the engine back to the stock position and make it steer with a new Signaw steering box, and fill the fire wall where the engine was, then I just picked up an other customer to do a frame off restoration on a 62 Impala SS. He's the original owner, and want's it all stock.
The Lark is getting there.
And here's the 62 SS
After these 2 I can start yours Ruffrida
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-31-2009, 09:19 AM   #697
4dranch
Shloooooong bed member #2
4dranch's Avatar
It really motivates us not so talented folks also.....
Super nice work Dennis..
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 08-31-2009, 10:06 AM   #698
Strodder
Strodder's Avatar
Thanks Dave
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-31-2009, 10:13 AM   #699
1964C10
1964C10's Avatar
Really nice work Dennis!! I have question, when you say to take your time welding in for example that filler piece for the signal light, about how long do you take to complete it and how long between doing a weld? I am novice at this and fixing to do some work on the body myself so I am trying to gauge at what speed I should be going. Thanks!
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 08-31-2009, 10:22 AM   #700
Strodder
Strodder's Avatar
Thanks for the complement. I cool it by spraying a mist of water on it from a squirt bottle, and then blow it dry with compressed air. I don't want it to cool too fast. When I can touch it with my hand I start tacking again. I get impatient and tack too many times in a row. I keep saying to myself to slow down.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
