Old 08-19-2009, 03:44 AM   #1
mrchev
mrchev's Avatar
How to fabricate a 67-68 slope nose hood onto a 1969-1972 truck.
I did this conversion on my 1970 Blazer. Some people have asked for me to post it and show how I did it. So, here are some photos of the finished product. I will say it's hard and takes time! I have about 20/30 additional pictures of how I did it (kinda step by step) if someone is wanting to make the undertaking. I'm only able to put 5 pics on here now.
Hope some of you are brave enough to try this. I makes your ride really look cool and different.
mrchev is offline   Reply With Quote
Old 08-19-2009, 03:55 AM   #2
OARNGESI
OARNGESI's Avatar
Re: How to fabricate a 67-68 slope nose hood onto a 1969-1972 truck.
Your blazer looks great those hoods really look great way better than a cowl hood
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 08-19-2009, 06:27 AM   #3
c10crazy
Like a Rock!
c10crazy's Avatar
Very cool Looks like your bumper is smiling I remember another board member did a write up on this awhile back.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 08-19-2009, 09:13 AM   #4
Ackattack
Ackattack's Avatar
did you have to use a 67-68 hood latch?
I have thought about doing this, but don't know where to start.
Ackattack is offline   Reply With Quote
Old 08-19-2009, 12:41 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very cool give us some info if ya got it..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-19-2009, 01:03 PM   #6
mrchev
mrchev's Avatar
About the hood latch. I used the 1970 hood latch mechanism that was on my truck. And the latch pin on the hood was the same I believe from 67-72. Here are some more photos.
Bruce
Old 08-19-2009, 01:45 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome "subtle" modification Bruce!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-19-2009, 09:11 PM   #8
70c10
67-72 Addict!
70c10's Avatar
Cool Could you explain a little on how you did it?. Is the last pic showing the line you are about to cut or is that where it's welded?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-19-2009, 09:36 PM   #9
mrchev
mrchev's Avatar
Well, the last pic is the line I cut with a cut off wheel. I just came up (I believe) 2 inches from the leading edge and marked it all the way down. Then, I used a strait edge and drew a line. Then, used a very thin cut off wheel and cut through. In that photo the bottom side of the hood is still attached. I'll try to get more photos.
Old 08-19-2009, 09:40 PM   #10
70c10
67-72 Addict!
70c10's Avatar
Thanks. Would love to see more pics showing how this was done. Cool truck!
Jim
Old 08-19-2009, 10:23 PM   #11
mrchev
mrchev's Avatar
Here are a few more photos.
See how I slid the leading edge section of the hood I cut off.... under the existing hood? This brought the hood to the length it needs to be to shut with a 1969-1972 grill shell.
But, when I did that, the front section of the hood I cut off was too short on the ends(didn't reach to the sides of the fenders.) Meaning I had to take the section I cut loose for the front of the hood and splice it in the center to (spread it out to the edges of the hood sides. Then, I spliced in a half inch wide piece of sheet metal in the center of the hood front section.
Hope that is of some help.
Old 08-20-2009, 09:10 PM   #12
70c10
67-72 Addict!
70c10's Avatar
Thanks for the pics!
Jim
Old 08-20-2009, 09:18 PM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Very nice. Clean. One of those little "things" that those who don't know these trucks very well may ponder and finally figure out. Yep, subtle.
Member Nr. 2770
Old 08-20-2009, 09:27 PM   #14
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
You might consider doing a write-up in the "body and paint" section.
Awesome!
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 08-20-2009, 10:31 PM   #15
mrchev
mrchev's Avatar
In these photos you can see the front section that was cut into and you see the front right side sitting on the grill there. Then I slide the leading edge of the cut off hood under the original hood and used sheet metal screws to hold it. I drilled the holes in the original hood larger so I could go back and rosette weld then up. Hope that gets someone interested in trying this.
Bruce
Old 08-21-2009, 12:37 AM   #16
PHAT TONY
PHAT TONY's Avatar
I see this done on "Low Buck"; seems a more lengthy procedure there though.
PHAT TONY is offline   Reply With Quote
Old 08-21-2009, 06:21 AM   #17
c10crazy
Like a Rock!
c10crazy's Avatar
After you slid the cut pieces under the front edge of the hood, how did you blend the difference in height? Do you build that up with filler or metal? Looks awesome!
69 LWB
Old 08-21-2009, 02:21 PM   #18
ERASER5
ERASER5's Avatar
That's because Low Buck had a 69-72 hood with a 67=68 nose graphed on. This is a 67-68 hood being shortened.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-23-2009, 12:13 PM   #19
mrchev
mrchev's Avatar
Hey ERASER5, Can you give me a link to Low Buck? I'd like to see that hood and nose graph for curiosity? Thanks Bruce
Old 08-23-2009, 12:44 PM   #20
mrchev
mrchev's Avatar
Here are a few more photos of the hood mod.
I forgot to mention too. When reattaching the (2) leading edges of the hood to the factory hood. Be sure to have your grill shell on and in place. Lining up the leading edge of the hood and grill shell with a perfect gap (about 1/4 to 3/8). Remember, have the hood aligned and on perfect at the back when doing this! Because if you align this later, all your leading edge work will be off, and all that work looks bad. OK................
Basically, I did a spot weld every inch, then went back and spot welded every half inch, then quarter inch, and eight inch. Then did a half inch long weld with the welder turned down low (to tie the stitch welds closed). Alternating from each end of the hood and center area of the hood to keep the heat low and warping to an minimum. Then, I removed the screws that were high up on the hood (that were in the slope area) and rosette welded those closed. Those I had to do in steps because they wanted to warp. So, I would close up a little amount of the hole and move to another one and close up a little and come back. Welding these rosette holes will warp your slope! I'm telling you, you don't want to warp this area. During prep time all your effort will go to crap if you have to shrink, stretch, beat and modify with bondo this slope area. This will make of break your work later. Go Slow!
Old 08-23-2009, 03:18 PM   #21
GR8-68
GR8-68's Avatar
very cool mod you did there
GR8-68 is offline   Reply With Quote
Old 08-23-2009, 03:30 PM   #22
Rokcrln
Rokcrln's Avatar
Looks great it is one of my favorite mods I have done as well. On LowBuck I did use a 67 hod but the front latch section of a 70 hood. This gave it a totaly stock look from under the noise as well. Here is a link to the How-To. Hard to believe that was over 2 yrs ago already
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 08-23-2009, 04:37 PM   #23
mrchev
mrchev's Avatar
Kevin
LFD Inc.
Kevin, beautiful workmanship, details and instructions!
Yes, I never saw a article about doing these hoods. I just sat and looked at that hood 100 times to finally decide where to cut and what would decrease the labor. So, that's how I came up with my spin on the hood. But, making this hood is a commitment. Thanks for showing me the link and your work! Nice.........!
