Old 08-24-2009, 04:30 PM   #1
'72customdeluxe
Heater core problem?
After I shut the truck off today I noticed a little bit of water under the heater core. I did run the a/c today, and just got it working again two weeks ago, so i'm not used to where from and how much the a/c drips. Is it normal to get a little water from under the big box on the firewall? I know a/c does normally drip. I'm questioning wether I should carry around some vice grips and a jug of water (will anyway)
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 08-24-2009, 04:52 PM   #2
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Re: Heater core problem?
Every vehicle ever made drips after running the A/C... that just means it's working! Start to worry if it is antifreeze.
basemodel67 is offline   Reply With Quote
Old 08-24-2009, 06:19 PM   #3
'72customdeluxe
Yeah, I just didn't know if it would come out of that box. It's clear water. Thanks
Old 08-24-2009, 06:30 PM   #4
69GMCLonghorn
69GMCLonghorn's Avatar
I think there is a drain on the A/C trucks. It should not be just souping out of the box. Check exactly where it is originating from, and if you can see that drain tube that dumps to the ground. It may be clogged.
69GMCLonghorn is offline   Reply With Quote
