Old 08-25-2009, 12:06 PM   #1
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Brake Rotor Replacement '88 Burb 4WD
First you will need a pair of needle nose pliars. Remove this locking ring circled in red.
Then you can remove the hub assembly.Next you will need a pair of snap ring pliars to remove the snap ring that's holding the stub axle in place. After that you will need the hub socket that has 4 prongs. Remove the outter nut to access the flat 4 pronged hub activation washer. After that you have 1 more hub nut that takes the 4pronged hub socket. Once all that comes out and you have reomved the brake caliper the hub and rotor assembly will pull off. To seperate the hub from the rotor you have to tap out the wheel studs...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 08-25-2009, 01:17 PM   #2
bigbadjohn84
yea. I knew somebody out there had a little more info on that. its simpler than it seems. but as they say, if it was easy everyone would do it lol. most of my stuff is 2wd with the exception of my trusty ol farm rig, the 76 heavy half
bigbadjohn84 is offline   Reply With Quote
Old 08-25-2009, 01:18 PM   #3
kw
kw's Avatar
The second snap ring you mention. Is that the one acting as a retainer for that spring?
kw is offline   Reply With Quote
