Old 08-25-2009, 11:20 AM   #401
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Glock's new project: "Fred"
Budget = telling your money what to do, instead of wondering where it went. Try it, you might find you have more than you think!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-25-2009, 11:39 AM   #402
bigbadjohn84
Im working on that.. slowly but surely.. spent two months unwanted vacation this summer.. just trying to catch back up no. got two jobs hehe.. keepin my head up though
bigbadjohn84 is offline   Reply With Quote
Old 08-25-2009, 12:13 PM   #403
menace121978
menace121978's Avatar
ya, without our monthly budget our money would be who knows where... mine always comes the last of the month usually. what ever is left over from the mortgage and cars goes right to the build/savings. granted sometimes things come up and we have to skip a month but it works out good for the most part.
were planning our vaca for the end of sept. so theres nothing happening for the the build or savings next month COLORFUL COLORADO HERE WE COME!!! (as long as school doesnt get in the way)
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-25-2009, 12:18 PM   #404
glock35ipsc
Hmmm, we are planning a Colorado get-together/BBQ on Sept 27th, maybe you will be here for that? That would be awesome! Take a look at the "August Get Together" thread in the Colorado section. Yeah, it started out to be August, but got bumped to September.
Bob
Old 08-25-2009, 12:42 PM   #405
menace121978
i'm grinning ear to ear!! i just talked it over w/ Amy and she just has to check her class syllabus for that week but it is looking good!!
i'll put in my request off today for week of sept. 27th. if it works out we'll get friday saturday before off and we can take our time getting there. if not i'll drive straight through sat. night after work!!!! woooo whoooo!
oh yea, i'll check out the thread for time and what to bring. bummer i wont be in the truck...
"Dennis the Menace"
Old 08-25-2009, 01:36 PM   #406
glock35ipsc
Harness and PCM are here! WOOHOO!!! Now, I'm going to note every connection that they left in the harness so when I go to put a 5.3L in Goldie I can do this myself and save a few $$$.
Bob
Old 08-25-2009, 01:53 PM   #407
bigbadjohn84
yep! and post all that wonderous info that you are so famous for glock!
Old 08-25-2009, 01:56 PM   #408
glock35ipsc
Oh, you can count on that!!
Bob
Old 08-25-2009, 03:22 PM   #409
JohnC
JohnC's Avatar
Yeah that whole budget thing is why I haven't done anything to the truck. Started off good, then got the bill for the engine. Bye bye money saved for truck. Now it's slowly building back up.
JohnC is offline   Reply With Quote
Old 08-25-2009, 03:34 PM   #410
glock35ipsc
That's the only way to fly!
'Debt' and 'credit cards' are words not found in our vocabulary at our house. If we don't have the , we don't buy until we do. That, and a budget, has made life much easier. And better.
Bob
Old 08-25-2009, 04:02 PM   #411
nlped
nlped's Avatar
^^^ amen!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-25-2009, 04:21 PM   #412
mcbassin
Still Learning
mcbassin's Avatar
we need pics of the harness!
Old 08-25-2009, 04:28 PM   #413
glock35ipsc
I need to find my camera first!
No seriously, I have no idea where it's at......
So this will have to do for now:
2006 Silverado harness, starting at PCM connectors and moving out from the PCM -
BARE WIRES:
White - To tach, 4cyl signal
Green/White - To fuel pump relay control, 12v +
Green/White - AC cycling switch
White - To brake light switch, cruise
Green/White - AC clutch enable relay control
Purple - To brake switch, for TCC
Green/White - VSS, to speedo
Green - To OBD II connector, in vehicle
Brown/White - To SES light
3 Red wires - Each to a 12v key-on fused power source
1 Orange wire - To a 12v battery fused power source
1 Purple wire - To starter solenoid (tie trucks starter wire to this one, or leave it alone and use trucks wire to the starter)
CONNECTORS:
• Electric fans (high and low, I will have to supply the ground)
• TAC module
• Wires for cruise: Dark Blue, Gray/Black, Gray
• DS coil packs
• DS injectors
• Alternator
• Coolant temp sensor (front of left head, for PCM)
• Ground
• AC compressor [probably won't need/use]
• AC pressure switch (on AC line) [probably won't need/use]
• Starter solenoid (see “1 Purple wire” above)
• Crank sensor
• Oil level switch (in oil pan)
MAIN HARNESS SPLITS IN TWO HERE:
One:
• MAP sensor
• Passenger side O2 sensor, front
• MAF
• PS coil packs
• Ground
• PS Injectors
• Throttle body
Two:
• Knock sensor harness on intake manifold
• Oil PSI switch (behind intake manifold, for PCM)
• Cam sensor
• Ground
• Driver side O2 sensor, front
• Transmission, drivers side
• Transmission, VSS, tailhousing
• Transmission, passenger side
Bob
Old 08-25-2009, 04:53 PM   #414
glock35ipsc
So Dennis.... if you are going to crash our Colorado Get Together, I suppose that means Fred needs to be on Gen III power by September 27th?????
Bob
Old 08-25-2009, 05:13 PM   #415
menace121978
or at least ready for the 1st fire up by then! that would be a sweet welcoming!
"Dennis the Menace"
Old 08-26-2009, 09:54 PM   #416
glock35ipsc
Hmmm, I thought I had posted a before pic of the harness. I'll have to look on my computer at work tomorrow. But here is one of the reworked harness. And A pic of the problem with the rear end. grrrr.....
Bob
Old 08-27-2009, 07:39 AM   #417
nlped
nlped's Avatar
^^^ Wow...they screwed that one up real good
Carter
Old 08-27-2009, 12:01 PM   #418
menace121978
new/reworked harness looks great Bob. now which rearend is that?
"Dennis the Menace"
Old 08-27-2009, 12:06 PM   #419
glock35ipsc
It's the one out of the burb. For some reason, the tape measure I used to measure Fred's rearend has an error on it somewhere, because Fred's rear is wider than I thought. Damn cheap tape measures!
The are actually the same width, so I will just put the ring and pinion out of the burb rear end into Fred's.
Bob
Old 08-27-2009, 12:15 PM   #420
menace121978
cool, so you'll end up w/ the final gearing you wanted... 3.42's!
looks like your hitting it pretty hard trying to make that deadline
i hate it when the numbers arent in the right order on those cheapo tapes!
"Dennis the Menace"
Old 08-27-2009, 12:21 PM   #421
glock35ipsc
It was at least an inch and a half shorter than all the others!
Yup, 3.42 is what I wanted all along. With the 275/60's, it will put me a 2250rpm at 78mph. Perfect!
Bob
Old 08-27-2009, 01:55 PM   #422
bigbadjohn84
yea, I thought all the rearend widths were in the same size catagory for those years.. now the 88-98 are wider in the trucks, but the spring perches are in different locations. something to consider tho
Old 08-27-2009, 02:55 PM   #423
nlped
nlped's Avatar
I ended up putting a '96 rearend in my truck. I had to cut off the perches and shock mounts and weld them back on (wish I had thought that through as I am now wanting to do a flip), but it is a 30 spline, with an Eaton Posi, and 3.42 gears so it accomplished all of my goals at the time.
Carter
Old 08-27-2009, 03:11 PM   #424
glock35ipsc
Mid 90', eh? 5 lug.... do you remember how much difference, if any, in the width? U-joint the same?
Bob
Old 08-27-2009, 03:59 PM   #425
bigbadjohn84
if I am not mistaken it puts the rear width right in line with the front. the one I used on my 84 4wd evened them out
