Old 08-26-2009, 04:02 PM   #1
el_gureo
el_gureo's Avatar
AC Heat switch controls
I have a 1972 truck. It’s was a non-AC truck but the previous owner added AC to the truck. I’m not sure how this is normally done but they used the Air/Fan control for the AC. So the AC has two speeds. That’s ok, but what valve does the Air Fan lever control?
I ask because when I get the truck I tested the AC and heater and they worked. So the summer while going down the highway with the AC on heat was coming out of the floor. I assumed that as I moved the control lever over its opening a “heater” valve. So I disconnected the cable to the Air Fan control lever. Great no more heat blowing, but now the heater doesn’t even seem to work at all.
I get that the “heater” fan switch is now the AC fan switch but how do I fix this? How can I make them both work?
Any help would be appreciated.
-Breakin sh1t sense 1971
el_gureo is offline   Reply With Quote
Old 08-26-2009, 07:48 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: AC Heat switch controls
Do you still have all the non ac parts under the dash and under the hood? is the ac under-dash or what?
Jurassic-1 is offline   Reply With Quote
Old 08-26-2009, 08:12 PM   #3
el_gureo
el_gureo's Avatar
The AC unit is in the dash behind the glove box. Im not sure about the original heater parts.
