08-25-2009, 11:42 PM | #1 |
Where is a place to buy firewall grommets?
I seem to be able to find every piece of rubber on these trucks except them.
Thanks |
08-25-2009, 11:48 PM | #2 |
Re: Where is a place to buy firewall grommets?
Yo! I just make a run to NAPA or ACE Hardware if I need that kind of item,...and cheap.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
08-26-2009, 12:10 AM | #3 |
the pollock
our NAPA osent supply then (bummer) but is there any in paricular you need? i'll beat the pick and pull again saturday picking up stuff
id be willing to grab and ship you a few for a few bucks.. p.s. take pictures of your specific firewall just to make dang sure i dont screw it up
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 Last edited by dammitmitchell; 08-26-2009 at 12:11 AM. |
08-26-2009, 12:12 AM | #4 |
6.0 powered square
I get mine a Harbor Freight
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
08-26-2009, 03:19 AM | #5 |
http://www.harborfreight.com/cpi/cta...emnumber=46724
dang 5 bucks is cheap, i'll definitely need these when i put my cab back together. So i would say this your best bet for firewall grommets.
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
08-26-2009, 12:55 PM | #6 |
I know my local ACE hardware has them and NAPA too. You could also try JCWhitney heres a link to them: Firewall Grommets
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
08-26-2009, 01:11 PM | #7 |
I have car A.D.D.
I will emphasize a point made earlier...Harbor Freight: 180 piece set for $5. How can you beat that?
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
08-26-2009, 01:12 PM | #8 |
Have you checked with your local GM dealer? The stuff for trucks tends to be available longer than stuff for cars.
Also check with Wes at www.classicheartbeat.com if he doesn't stock it in oem or repro he seems to have some great sources for things like this and they will be the correct item. Last edited by mr48chev; 08-26-2009 at 01:18 PM. |
08-27-2009, 08:02 AM | #9 |
Still plays with trucks
Same set I was going to suggest from HF.
08-27-2009, 11:51 AM | #10 |
I have car A.D.D.
Another option would be to go to your local junk yard and find OEM grommets from other vehicles that would fit the holes you need plugged.
08-27-2009, 02:50 PM | #11 |
+1 or I know O'Reilly's has them in stock too.
