Old 08-27-2009, 04:03 PM   #426
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Glock's new project: "Fred"
^^^ THAT'S what I wanted the burb rear end for! Which is why I was excited at first to think the burb rear end was wider. Then bummed to see my tape measure had lied.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-27-2009, 04:11 PM   #427
bigbadjohn84
well.. goodluck on finding a 88-98 in that gear. I am having issues myself. they want an arm and two legs for a rear with the G80 5lug and 3.73! go figure .. the nerve..
bigbadjohn84 is offline   Reply With Quote
Old 08-27-2009, 04:20 PM   #428
glock35ipsc
I'm finding a bunch with 3.42's, just not anywhere near me. I may have to take a trip to the yard this Saturday to see what's close by.
Bob
Old 08-27-2009, 04:35 PM   #429
bigbadjohn84
yea. the most popular availiable in my area seem to be 3.08 single trac. looks like I am gonna be stuck saving the funds and finding a GOOD shop to set up a new rear diff and ring and pinion. seems like all the street cars I have seen done my most shops end up with a whine after supposed set with a dial indicator. if I could do it, or at least had the tools, Id do it myself and save paying some jerkoff to set it up wrong lol
Old 08-27-2009, 10:01 PM   #430
nlped
nlped's Avatar
They were only about a 1/4" different per side. I can tell you that the 18x9.5 Boss 338 that I have for "Bob" fit beautifully with this rear. I actually replaced the u joint...twice...before I came to the realization that the stock one would have fit .
^^^ I did put the new Eaton in myself with new bearing and all, but I took about a dozen measurements with a dial indicator before I removed the stock carrier.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-27-2009, 10:09 PM   #431
HuggerCST
HuggerCST's Avatar
Have you tried car-part.com? I see several in Colorado.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 08-28-2009, 12:13 PM   #432
glock35ipsc
I did look there Wynne. The ones with prices start at $250. The local yard sells complete rear ends for $100 without drums, $150 with, but it's u-pull. I have a small portable hot wrench that will make that job easy.
Scored on eBay this morning, which required that I sign up again for Paypal. Guess I should change my signature?! I picked up a complete gauge cluster from a 90 Blazer for the electric speedo for $45. I sniped it in the last 20 seconds, and a guy put in his first bid in at the exact time as mine, but for $0.42 less than me!
I'll probably swap the entire cluster instead of just the speedo, except I like the original fuel gauge better. It says E, 1/2, F instead of the empty black circle, half white half black circle, and white circle. And it has a trip odometer too!
The lower left gauge spot is empty, so I will see if I can install my Autometer fuel pressure gauge there. That way won't have to mount it under the dash.
Bob
Old 08-28-2009, 12:28 PM   #433
menace121978
menace121978's Avatar
THAT WAS YOU!!??
J/K! nice score Bob. i'm going to go w/ the autometer gauges that fit in the stock bezel. that should eliminate any problems with the font matching. i'll just need an electric speedo and the rest manual gauges like the stock ones?.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-28-2009, 12:50 PM   #434
glock35ipsc
The stock gauges should be electric already (temp, oil psi). Even if not, I would go with all electric gauges.
Bob
Old 08-28-2009, 12:58 PM   #435
menace121978
oh okay... the only thing that is manual in the stock dash is the speedo which is going to change to electric. duh!!!!!!
"Dennis the Menace"
Old 08-28-2009, 01:00 PM   #436
glock35ipsc
Bob
Old 08-28-2009, 03:59 PM   #437
nlped
nlped's Avatar
I'm gonna build my own bezel out of aluminum and mount all my Autometer Phantom guages in it. I'm gonna relocate the radio, A/C controls and the left lower A/C vent at the same time too.
Not really relocate as much as move around. I have drawn it up a few different ways on Autocad at a friends machine shop, but that is the extent of it so far.
Carter
Old 08-28-2009, 04:04 PM   #438
glock35ipsc
Sounds cool, but......
be careful when you say you are just going to "move around" a few things on your dash
Ask me how I know that this can turn bad!
Bob
Old 08-28-2009, 05:06 PM   #439
nlped
nlped's Avatar
Yeah, I have already seen pics of the other truck. I don't have the skills to do that much modification. I do, however, have a huge drawer full of hammers from very small to a genuine BFH
Carter
Old 08-28-2009, 05:44 PM   #440
glock35ipsc
All metal fabrication starts with a hammer!!!
And sometimes it ends with one too, depending on how the original hammer work turned out!
Bob
Old 08-29-2009, 01:05 PM   #441
glock35ipsc
Captian's log, star date August 29, 2009. As the life fluid slowly drains from Fred, so begins the tedious transition towards a new life.
Bob
Old 08-29-2009, 01:08 PM   #442
menace121978
right on schedule! GOOD TIMES MAN!!
"Dennis the Menace"
Old 08-29-2009, 01:48 PM   #443
glock35ipsc
Yeah buddy! Lunch break now, then let the nuts and bolts fly!!
I had to do an oil change in my car first, then I somewhat put the burb rear end back together (less gears) so I could get it to roll again. Then I welded it to the leaf springs! Well, I kind of HAD to, since I cut the u-bolts to get it out!
Bob
Old 08-29-2009, 02:44 PM   #444
nlped
nlped's Avatar
Awesome!!!
Carter
Old 08-29-2009, 05:23 PM   #445
What happened to drive it a while?
I am just as bad.
Glad to see the transition starting and can't wait to see all the neato stuff in its rebirth.
Old 08-29-2009, 07:40 PM   #446
glock35ipsc
Um, yeah, what did happen there? Actually, my wife seems to be impressed that I drove it as long as I did! I put about 3000 mile on him at least.
Well, his old heart is on the floor. Had to take miscellaneous breaks here and there for different stuff.... my daughters ATV ran out of gas, so I had to stop and go rescue her. My brother stopped by to chat for a while. But it's out, and I'll get the trans out either tomorrow or.... whenever.
Now starts the clean up, picking apart the wiring to get all the stuff that runs to the ECM out, etc. I did find one problem with the engine plates though. The right side interferes with the AC compressor bracket to the point where I thought I would have to make new engine mount plates that set back 1", which would move the engine forward 1".
I got to thinking about it while I was in the shower, and I'm going to see if I can move the right engine stand on the truck back 1", then fab a new engine mount for the engine side. If it works, I'll make a jig so I can reproduce them since there are a few more of use doing this same swap.
Bob
Old 08-29-2009, 08:08 PM   #447
Poor Fred, He lost his heart.
But the quadruple-bypass will make him forget ll about it.
Showers are always great places to formulate the days work and hash out the next criteria.
Old 08-29-2009, 08:38 PM   #448
glock35ipsc
LOL, I get some of my best ideas while in the shower. And the dash for the 68? I dreamed that up while I was in the, um, well.. "back" office.
Here's my problem:
Instead of moving the entire stand, I think I can weld a gusseted plate to the back side of the stand, then re-drill new holes and move the rubber mount back. I think that will be fairly easy. Then I can clearance the AC mount just enough to clear the upper front bolt and an 1/8" piece of plate, then fab a mount that sets back 1'.
Bob
Old 08-29-2009, 09:52 PM   #449
Manbearpig
Manbearpig's Avatar
If you wanna get rid of that TH350 shift indicator out of the cluster, I'm your guy.
1972 GMC C10
Manbearpig is offline   Reply With Quote
Old 08-29-2009, 10:00 PM   #450
glock35ipsc
Sorry man, my cluster has a 4 speed indicator, and so does the new one I just got off of eBay.
Bob
