Old 08-25-2009, 10:55 PM   #1
BCOWANWHEELS
Where to buy front sway bar mounting brackets
I need a set of front sway bar mounting brackets that are for lowered trucks. Anybody know who sells just the brackets ( 2 )
bob in tn.
423 384 8938
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-25-2009, 11:02 PM   #2
powell72
powell72's Avatar
Re: Where to buy front sway bar mounting brackets
ECE, second item down-
http://www.earlyclassic.com/catalog.aspx
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 08-25-2009, 11:04 PM   #3
powell72
powell72's Avatar
Okay, my link didn't work, but just chose "sway bars and components" in the select catagory box on the left, they're $19 a pair.
Chris
Old 08-25-2009, 11:10 PM   #4
BCOWANWHEELS
Thanks just what i needed
Old 08-26-2009, 01:38 AM   #5
mclairmo
I think CPP has them, too.
mclairmo is offline   Reply With Quote
Old 08-26-2009, 11:40 PM   #6
pritch
pritch's Avatar
Thanks for the link. I need to get some of those as well. But with drop spindles, do you use the stock or lowered brackets? Reason I ask is that I'm led to believe that you use everything stock with drop spindles.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 08-27-2009, 03:54 PM   #7
neonlarry
neonlarry's Avatar
Use the lowered, more ground clearance.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-27-2009, 04:50 PM   #8
mclairmo
x2
Old 08-27-2009, 09:01 PM   #9
SCOTI
SCOTI's Avatar
For spring & spindle combo drops (5-6") up front, you can mount the sway bar directly to the frame rails & skip those brackets. You gain the benefits of the sway bar w/o the interference issues.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-27-2009, 11:10 PM   #10
pritch
pritch's Avatar
Cool. That makes sense, and the lowered ones are much cheaper than the stock.
'68 Panel
'68 C-10
Ol' Green
Old 08-27-2009, 11:48 PM   #11
BCOWANWHEELS
Boy that is a great idea. My 72 is low so i,am gonna give that some lookin into.
Thanks for the frame mount tip.
Bob
Old 08-28-2009, 12:14 AM   #12
SCOTI
SCOTI's Avatar
Bob
I've done all of mine that way w/no problems. Both small & big bars, mounted in Energy Suspension poly bushings/brackets (get the p/n's w/the zerk fittings so you can grease them).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-28-2009, 12:22 AM   #13
BCOWANWHEELS
I JUST BOUGHT A SET OF NEW MOOG brand bushings and come to find out there poly. i got them from oreilly's too. bet i could put a grease zerk in the mounting brackets and drill a small grease hole in them. do they squeek or something with no grease ?
Old 08-28-2009, 12:26 AM   #14
SCOTI
SCOTI's Avatar
If they get dry & dirty (meaning see a bunch of miles) they can get squeaky. The Energy Suspension bushings w/the zerks are actually fluted on the bushing itself to help transfer the grease.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-28-2009, 12:31 AM   #15
BCOWANWHEELS
what is the part number of the energy susp. with the zerks
Old 08-28-2009, 12:54 AM   #16
VA72C10
VA72C10
VA72C10's Avatar
So with bags and spindles, this is the best solution and not the lowered mounts? Is there a recommendation of where to mount them on the frame?
Old 08-28-2009, 09:10 AM   #17
SCOTI
SCOTI's Avatar
My set-ups have consisted of cut coils w/spindles. I bolted the bar to the a-arms & used a jack to raise the center of the bar until the mounts rested solidly against the frame rails. I then marked the C/L of the holes & drilled.
I can't say 100% on the bagged installation. I swapped to a different bar & different front arms when I went through changes on my front suspension a while back & the truck never made it back on the road. I don't see any reason why it wouldn't under similar circumstances (limited/normal suspension travel). There could be an issue w/extreme travel.
Best solution? That's purely subjective. I don't see the need in buying something if I don't need it. This method has worked well for me so far. I did my 68 & 74 both like this. My current build will also be done this way but it will be bagged all around. I'll get back to you on functionality then.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
