Glove box help
Is there a trick to removing and installing the glove box interior on an AC truck?
I had to remove mine to work on my diverter box (thanks for the help) and about ruined mine taking it out, there has to be a trick. Thanks Mark |
Active Member
![]() Join Date: Jul 2007
Re: Glove box help
No trick. Just some effort.
Mine doesn't have a/c but I still had to manuever, bow, and force the sucker in the front. Seems like I read someone say that they installed from the backside... but not sure. |
Re: Glove box help
It's a pain....
Old Skool Club
![]() Join Date: Jun 2001
Re: Glove box help
About six (or so) screws hold it in. Then, put your tongue in between your jaw teeth and start "finessing" the cardboard part. If you expect to be able to successfully remove an original glove box insert, perish the idea. If you are then able to remove it w/o destroying it.....you're a good finagler and should have no trouble dealing with my ex-wife.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: Glove box help
I removed it and reinstalled it without destroying it but....I would think there would have to be an easier way or a trick?!
Yes it was a pain! |
Re: Glove box help
I've pulled mine out and put it back in. I jammed it in from the front.
70 Chevrolet=Obsession
Re: Glove box help
I have no experience with installing a glovebox with air, but I slid my new non-air one from underneath the dash and up from behind. Wasn't too hard.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
Re: Glove box help
You just have to cram it in but put some masking tape around the opening in the dash so you don't scratch the paint. Getting it out is alot harder. If you've still got it out, I would order a new one to install. They are pretty cheap.
Re: Glove box help
Re: Glove box help
Its back in. I put some duct tape around the glove box to add strength where it was looking weak. It looks perfect installed but I will be buying a new one eventually.
