Old 08-27-2009, 09:58 PM   #1
jamesi20
jamesi20's Avatar
fresh air vents
How do you put new gaskets in the fresh air flaps? kinda looks like you have to take the rivets out and separate.I have no idea where you would get rivets that small.Any advise would be appreciated,
jamesi20 is offline   Reply With Quote
Old 08-27-2009, 11:34 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: fresh air vents
My instructions say:
Remove air vent doors from kick panels.
With a screwdriver, gently expand pinch seam which retains old rubber seal. Slowly work around door until seal can be slipped out.
Clean and paint doors.
Slip new seal into edge of door. Gently stretch seal working around rest of door, inserting seal into slot as you go.
Pinch seam onto seal only enough to hold seal.
Very lightly coat seal with rubber lubricant.
Reinstall door in kick panel.
Sounds like the rivets don't go through the rubber seal. I think I will put a small amount of weatherstrip adhesive around the slot in the door before I install the seals. If you are going to do that it probably wouldn't hurt to test some of the adhesive on a scrap piece of the seal.
LockDoc
Leon
Old 08-28-2009, 08:41 AM   #3
jamesi20
jamesi20's Avatar
Re: fresh air vents
Thanks Leon,I'll give it a shot.
Old 08-28-2009, 09:11 AM   #4
LockDoc
LockDoc's Avatar
Re: fresh air vents
No problem. Let us know how it works out for you.
LockDoc
Leon
Old 08-28-2009, 11:50 AM   #5
jamesi20
jamesi20's Avatar
Re: fresh air vents
Leon,I think the instructions you have are for 73-87 trucks.The seals for 67-72 are one piece and is sandwiched between the two flap plates.I talked to a couple of vendors and they said you have to drill the rivets out and replace.However none that I talked to had those small rivets and recommended that I try the home depot or a hardware store.I'll see if I can find the rivets and let you knoe.Thanks,Jim
Old 08-28-2009, 11:22 PM   #6
LockDoc
LockDoc's Avatar
Re: fresh air vents
I took mine out of the package tonight and they are one piece. Now I'm confused...
LockDoc
Leon
Old 08-28-2009, 11:31 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Re: fresh air vents
Use pop rivets. I did both of my trucks. Real easy job.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-29-2009, 12:59 AM   #8
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
Re: fresh air vents
i got two sets of the vents im going to rebuild and looked up the rivets online and found them!! but to get the tools to do it like original will cost alot. unless you dont mind the little nub on one side of pop rivet. thats the direction i would go!!! its quick and easy and plus nobody would see them any ways!!
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 08-29-2009, 02:07 AM   #9
Daves72'GMC
Smile Re: fresh air vents
I did mine when I restored my truck.You have to drill out the old rivets,repaint the 2 metal plates and then put in the new seal between the metal plates and put new rivets in the plates to hold them together.Good luck.
Daves72'GMC is offline   Reply With Quote
Old 08-29-2009, 08:12 AM   #10
Green Machine
Green Machine's Avatar
Re: fresh air vents
Drill em out and we used very short aluminum pop rivets, steel pop rivets may dent the metal because they are harder to pinch off.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-29-2009, 09:10 AM   #11
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Re: fresh air vents
When I did mine I used the small rivets that are used on the vent window frame rubber, along with the small tool that is sold by the vendors to be used on the vent window rivets.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
