Old 08-29-2009, 12:14 PM   #1
thump16
thump16's Avatar
Cab trim
How does the trim that runs around the sides and back of the cab under the rear window stay attached. My Scottsdale never had it and I wanted to put some on.
Sledge
thump16 is offline   Reply With Quote
Old 08-29-2009, 01:14 PM   #2
thump16
thump16's Avatar
Re: Cab trim
can someone help me?
Old 08-29-2009, 02:45 PM   #3
bigblock73
yeller
bigblock73's Avatar
Re: Cab trim
The rear piece slides over clips that are attached to the back of the cab itself, the side pieces then go on, are are bolted on from inside the cab.
It will not be real easy to install the rear clips, as there were studs welded to the back of the cab that the plastic clips attached to.
I suggest going to a JY, and taking apart a truck that has this setup...to determine if this is something you can do, or still want to do.
bigblock73 is offline   Reply With Quote
Old 08-29-2009, 02:53 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Cab trim
you can use small rivets for the clips but you have to be very careful marking out the holes and all
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-29-2009, 07:07 PM   #5
thump16
thump16's Avatar
Re: Cab trim
On second thought. I'll leave em off. I'll go with the lower side trim instead. Thanks guys
Sledge
