Old 08-29-2009, 02:12 PM   #1
Ronm909
67GMC Slammed
Ronm909's Avatar
Centerline smoothie question
need some help, I want to order a set of these smoothie centerlines but they dont offer any backspace options. this is what they have and not sure if it will work.. for the rear 22x9 (5.5 BS) and front 20x8.5 (5.4 BS). thats the only option. I am running a 10" step notch and a porterbuilt dropmember. can I make it work, I will run spacers if I have to. oh ya I have a 67 short fleet.
Ronm909 is offline   Reply With Quote
Old 08-29-2009, 02:58 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Centerline smoothie question
I think they will be fine.
I know alot of people run a 20x8.5 (5.25" BS) with a Dropmember.
You might have to run a spacer on the rear.
Which rearend do you have? 67-70 (1.5" narrower overall) or the wider 71-72?
My '71 2wd blazer has the wider 71-72 style 5 lug rearend,... and I'm running a 20x9.5 wheel (with a 5.5" BS)
Keith
Convert to disc brakes.
Old 08-29-2009, 05:33 PM   #3
Ronm909
67GMC Slammed
Ronm909's Avatar
its gets more complicated, the rear end came out of a 87 suburban. thats how I converted to 5 lug. I am gonna go measure it.
Old 08-29-2009, 11:07 PM   #4
lolife99
lolife99's Avatar
BEST answer on here.
MEASURE for yourself!
Keith
Old 08-29-2009, 11:47 PM   #5
Ronm909
67GMC Slammed
Ronm909's Avatar
thats a litlle hard to do, all I have is a frame on the floor, so thats why I am asking, I will be building my own rear suspension and I like to have rims and tires before I do anything.
Old 08-30-2009, 12:07 PM   #6
fiddy9apache
fiddy9apache's Avatar
it will work. ive had my set of 20/22 in smoothies on my 59, 67, 86, and many 88-98 trucks. all of them were bagged or static dropped a few inches off the ground.
only real problem i had with mine is you will need to grind on the snout of the rotor to get the front center cap to fit on the 72-87 style front suspension. my 59 has the front clip off of a 85 suburban and the rearend too, they rub the inside of the rear fender well alittle but nothing a very small spacer wont fix. but since im going to run my bonspeeds instead im not worried about it.
fiddy9apache is offline   Reply With Quote
Old 08-30-2009, 05:21 PM   #7
Ronm909
67GMC Slammed
Ronm909's Avatar
I not woried at all about inside rub, I may not even run a bed floor and if I do it will be raised and cut accordingly..Mainly what I am asking is this back spaceing gonna work??? rear 22x9 (5.5 BS) and front 20x8.5 (5.4 BS)
Old 08-30-2009, 05:59 PM   #8
SCOTI
SCOTI's Avatar
Yes, that back-spacing will work. It's very similar to what N2billet is running on his 'Tootsie-Roll' project (20x8.5 w/5.25"bs; 22x9 w/5.50"bs; DM front & rear). . . .....
http://67-72chevytrucks.com/vboard/s...42&postcount=8
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 09-01-2009, 10:16 AM   #9
duceducenine
duceducenine's Avatar
had the 20 X 8 on my C10 and C5 no issues...255 35 20 tires
duceducenine is offline   Reply With Quote
