suspension swap?
I have located a 76 blazer chassis that has great drivetrain. I am thinking about putting it in my 67 4x4 burb.the main reasons that I intend to do this are for driveability and parts availability. what I am curious about is unforseen problems like changing man brakes to pwr brakes, and installing pwr steering. Are the springs interchangable?...what I plan to do is remove the blazer axles and put them the burb are the u-joints the same or willl I need crossover joints?? any help is greatly appreciated
member
Re: suspension swap?
I believe that most of the parts you mentioned are interchangeable except the springs. You will find them to be longer. I also believe the left front framehorn on your burb will need a conversion plate to mount the power steering gearbox. Good luck with your project!
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide Last edited by olblue60@aol.com; 08-30-2009 at 07:10 AM. |
