Old 08-28-2009, 02:54 AM   #1
72lb4x4
72 truck, 85 NP208 TC and shifter dilema
I have a 72 K10 with a 4 speed and NP208 from an 85 truck due to a PO's somewhat less than infinite wisdom. It also has the crappy shifter from the 85.
This piece of junk sort of (in my case) bolts to the floor and has a nasty plastic console thing that lays pathetically over it.
It seems that the TC shifter should/would mount to the TC adapter, but in this case, there are no bolt holes.
I've been eying a few shifters on Dodge 4x4s in it scrap yard, and bought a shifter here for a 205, that I think is actually for a 203, but there's no easy way to mount them.
So after that windy introduction, does anyone have any shifter recommendations? I have searched the internet and checked on 4x4 aftermarket web sites but haven't found anything but twin stick setups, which aren't for a 208.
I'm an orphan. Apuva! (the finns, if any will laugh at that)
72lb4x4 is offline   Reply With Quote
Old 08-30-2009, 11:03 PM   #2
msgross
msgross's Avatar
Re: 72 truck, 85 NP208 TC and shifter dilema
ttt, anyone have a suggestion?
I don't know 85's so I am of no help... Should be some aftermarket support..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-31-2009, 04:53 PM   #3
Gene
Gene's Avatar
Ive got a 208 adapter that came out of an 85 Blazer and it doesnt have any holes other than the ones for the case??
Gene is offline   Reply With Quote
Old 09-07-2009, 11:51 AM   #4
ghettoluxury
ghettoluxury's Avatar
the shifter you have is the only one that will work unless you want to start fabricating
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 09-23-2009, 07:59 PM   #5
72lb4x4
I sort of lost track of my own post...
I pretty much know I'll need to do some fabricating, but was hoping for suggestions for a shifter to use as a starting point.
Thanks for the replies though.
Old 09-24-2009, 11:48 AM   #6
Curt's_72
Curt's_72's Avatar
My truck has this same setup. I like it. It shifts smooth, and looks very stock. The first picture is the way it looked when before I blew it apart to restore it, and the second is how it looks now, showing how the mechanism mounts to the floor. I like this setup. It was installed prior to me buying it, so I had no input. I did some tweaking to the shifter rod to make it smoother, and I still need to locate a plug for the light so it will show up at night.
Curt's_72 is offline   Reply With Quote
