Old 08-31-2009, 09:54 AM   #1
Burt4x4
Burt4x4's Avatar
Re: My Build Thread (year+) on 71 Jimmy 4x4
Looks Awesome!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-31-2009, 11:23 AM   #2
RckyMntnKng
RckyMntnKng's Avatar
Thanks!
71 Jimmy: D60/14BFF, 9"F/11"B Lift, 350-350-203-205, Crossover Hydro steering, Beadlocks, Tube stuff and the bottomless cooler
RckyMntnKng is offline   Reply With Quote
Old 09-06-2009, 01:08 PM   #3
RckyMntnKng
Fun with the welder.
Did the rear recovery points. Made sure they are not going to come off unless it rips the truck in half. They attach with 3/8" x4 x4 steel angle bar to the top and side of the frame on both sides through the hole in the bumber. Braced them horizontally and vertically. Clevis is rated for about 5x the weight of the truck each. Should be overkill the way I like
Old 09-06-2009, 01:09 PM   #4
RckyMntnKng
Cut up a new steering shaft and installed it to the Borgeson joint. Re-used the pinned slip shaft for safety
The tube door are swinging on the hinges and painted.
still working on the latch, picked up some heavy duty slam latches to install and striker plates.
Doors came out better than expected and made good use of the old roll bar.
Old 09-08-2009, 10:08 AM   #5
Burt4x4
Burt4x4's Avatar
I like the doorbars, thought about doing that someday.
Old 09-08-2009, 12:46 PM   #6
jaros44sr
jaros44sr's Avatar
Whole build looks great so far, thanks for the pics of the tube doors, on my to do list! Where did you find that GMC Jimmy emblem?
Sliders look beefy enuff
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-08-2009, 04:24 PM   #7
RckyMntnKng
Good deal thanks guys
PO threw in those emblems as well as new floor pans, rockers, heater core etc the day I purchased.
Pretty sure they are all from LMC catalog
