Old 08-29-2009, 09:55 AM   #1
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Trailing Arm Bushings!!!!
Does anyone know the best way to remove the bushings from the trailing arms? I have new poly bushings that I want to replace the old ones with.
My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143
My Garage ..... http://www.hubgarage.com/mygarage/OCD69
jgrisafi is offline   Reply With Quote
Old 08-29-2009, 10:32 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Trailing Arm Bushings!!!!
They need to be pressed out. You can use a torch to burn them out, but it is a nasty process.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-31-2009, 09:00 AM   #3
dznucks
dznucks's Avatar
is there a way to press them out while the arms are still under the truck?
dznucks is offline   Reply With Quote
Old 08-31-2009, 02:56 PM   #4
fixit-p
fixit-p's Avatar
I did mine with a propane torch, I concentrated the heat on the inner sleeve instead of just trying to melt out the rubber, that way once the inner sleeve slid out with a screwdriver the rubber pushed right out.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 08-31-2009, 04:33 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You need to figure out if your new bushings reuse the old outer shells or not. Some do, some don't.
If so, just set the rubber on fire and it will burn out. Clean the shell with a wire brush and you're ready to install the new bushings.
If not, you definitely need a press or a real strong air hammer.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-31-2009, 06:15 PM   #6
AusTx68
AusTx68's Avatar
My poly bushings required the outer shell which made it easier on me to replace. All I did was drill holes into the rubber between the shell and inner bolt sleeve. Didn't take long. I made like 8 or 9 holes then stuck a big screw driver in the bolt sleeve and pryed it out. I then used a wire brush to clean out the shell.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 08-31-2009, 06:19 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Good idea. Much less of a mess than burning them out.
Articles-
"Refining Sierra"
Old 08-31-2009, 09:19 PM   #8
Wild83C10
Wild83C10's Avatar
I've taken out bushings this way as well.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 09-01-2009, 07:00 AM   #9
dznucks
dznucks's Avatar
Drilling it is.....i am replacing mine this weekend.
Old 01-02-2012, 07:02 PM   #10
C10NEWGUY
any idea what size wrench you needed for bolts? I have a 1 1/16 is biggest and it wasnt big enough! time to buy a new tool
1977 Chevy C10 RWD long bed
C10NEWGUY is offline   Reply With Quote
Old 01-02-2012, 07:36 PM   #11
72gmcshorty
72gmcshorty's Avatar
This is how i also did mine
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 01-02-2012, 07:45 PM   #12
Rawkus
mine were 1 1/8" if I remember right.
Rawkus is offline   Reply With Quote
Old 01-03-2012, 06:41 PM   #13
aggie91
I'm just glad to be here!
aggie91's Avatar
1 1/8" wrench is correct. I just took mine off the other day...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-05-2012, 12:55 AM   #14
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Yeah I think aggie is right.
I pressed mine out with the 20 ton press. Easy squeezy lol
John
1999 Toyota Tacoma 4x4
