Picture of your Dash!?
So I'm doing a stock rebuild on my 350, figure this is a good time to upgrade my gauges too.
So I have a 70, the only stock gauge that is working is the speedometer and it is off by 10-20mph... there are a mix of after market ones (oil, water, vacuum) in a cheap little pod bolted to the underside of the dash. what have you done to your dash to make it a little more custom? I have some ideas but really need some inspiration! Post some pictures, show me what you've done! thanks, Steve |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Re: Picture of your Dash!?
Here's mine, It's a mix of original and custom
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
low n' slo
![]() Join Date: Mar 2009
I like that kev looks good
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Always on the hunt...
![]() Join Date: Sep 2006
Here's my 72 K/5 dash...
Here is my custom dash
Thanks for the pictures guys!
Ryan, you've done exactly what I'm looking to do, putting aftermarket gauges in the stock dash! Questions, what brand gauges are those and how did you attach them to the grill? |
Do the white faced guages light up any better?
I have a new tach dash in my 72 Jimmy with all new bulbs with good grounds and it is adequate but could be better. Sorry to hijack your thread but I thought others may be interested also? Mark |
TILT COLUMN GURU
Yes, I think so. I have leds instead of bulbs and my guages light up blue.
#10 | |
TILT COLUMN GURU
Thank you~
Those are VDO series one gauges and my dash panel is not stock. I made it on my CNC mill. But I used to run a stock dash panel and got some plastic inserts that let me run aftermarket gauges. I just can't remember where I got them though. The company was a hot rod business in the Pacific Northwest area.
