04-07-2003, 08:09 PM | #1 |
Turbo 400?
How many quarts of trans fluid does a turbo 400 take with out draining the torque converter? Thank you
04-07-2003, 08:23 PM | #2 |
it depends if if has deep truck pan, a shallow car pan,if thers a cooler plus rad.if your looking just to change the filter..buy 6 qts you should be ok???
04-07-2003, 09:40 PM | #3 |
My 400 took 15 quarts....but that included torque converter, deep pan and cooler....
I'd say add 5 quarts, see if you have a reading, then add 1/2 quart at a time untill you can see it on the dipstick (engine running....) Remeber that the "add" mark is 1 PINT low, not a quart.......
That's right, I'm back in the game again. No it's not pink..... 1972 Blue and White Suburban. |
04-07-2003, 09:49 PM | #4 |
I'll try 6-quarts. It has the stock pan and has a cooler. Thank you
