Old 09-01-2009, 09:57 PM   #1
Wideopenracing15
Wideopenracing15's Avatar
Need some help/advice
Ok heres a little background, Im 15 and a sophmore in highschool. My dad pretty much gave me this truck ( a 69 gmc 3/4 ton)... But with a catch, the doors havent been locked in at least a decade. The Drivers side locks from the inside but the key is stuck. the passenger side wont lock from the inside but the key is free but wont turn to the lock side. I want a drivers side door because the window is stuck and i really dont want to have to take the tracks and everything out. I think i need a passenger side door because its rotted out where the bottom door panel screws are. Another problem which i think many share with me. I have a verrry limited budget seeing how i race go karts too. And advice on what would be the easiest/ cheapest route. I would really love to restore the truck adventually but for now i just need something to get me to school. Oh and im a gearhead so you really dont have to spell everything out for me.
You may have seen this truck on here but probably not
Wideopenracing15 is offline   Reply With Quote
Old 09-01-2009, 09:58 PM   #2
Wideopenracing15
Re: Need some help/advice
Oh and its got all the typical rust too. This might actually end up being a build thread
Old 09-02-2009, 12:27 AM   #3
hgs_notes
GEARHEAD
hgs_notes's Avatar
Just replace the door locks. It's easy enough to do and it's reasonably cheap. As far as the stuck window goes, pull the door panel and spray wd-40 or similar product into the regulator and onto the rollers in the tracks. Just work it back and forth with a helping hand on the glass. There is a good chance it will free up and be usable again.
You can shop for doors later. BTW, Lockdoc can probably fix you up for the locks, and very possibly the doors, and he's fairly close to you.
hgs_notes is offline   Reply With Quote
Old 09-02-2009, 01:42 AM   #4
Terakilla
Terakilla's Avatar
Good lookin truck, yeah new locks are prob your best bet, you may be able to take your current locks to a smith to clean and re pin them and get new keys,y locksmith doesn't charge much to do it. Hgs is right for the windows, maybe try pb blaster, I've had more success with it than wd40.
Terakilla is offline   Reply With Quote
Old 09-02-2009, 05:36 PM   #5
Wideopenracing15
Yeah i have tried WD40 on everything except the window part of it. i might give it a try today.
Old 09-02-2009, 06:03 PM   #6
Wideopenracing15
Oh and thanks guys!
Old 09-02-2009, 06:33 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Look at the window regulator when you have the door panel off.It may have a bad bearing in it and be hung up causing it not to turn.If that's the case you will need a new regulator.The drivers window is usually shot because that window gets operated way more than the other.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-02-2009, 09:39 PM   #8
BCOWANWHEELS
You need to remove the door panel and remove the entire lock-latch assembly. Then give it a good cleanning. Then lube it all real good with white lithium grease ( spray is best ) then reasemble everything. Its just froze up because it hasnt been used. You wont have to buy anything
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-02-2009, 10:00 PM   #9
Wideopenracing15
i have both door panels off. Might be able to do that this weekend. Thanks for all the help guys
Old 09-02-2009, 10:07 PM   #10
71swb4x4
71swb4x4's Avatar
There are a ton of board members in your area. You may check with them to see if they have solid doors.
Here are a couple: Lockdoc (Leon) http://www.67-72chevytrucks.com/vboa...er.php?u=25924
Bob 68327 (Bob) http://www.67-72chevytrucks.com/vboa...er.php?u=32759
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-02-2009, 10:30 PM   #11
Wideopenracing15
Im going to pm them in a few and see if they have anything. Ive talked to bob and hes close to my race track so he would be easier
