NOS Cruise Control parts 73 and up?
Here is what is left of I believe is a 73 and up unit. I used the servo and wire harness for my project. The switch is there and will work on the earlier units but is not the correct chrome one.
$99 shipped or best offer Paypal ad 3% Located in Seattle John Hepperle 425-417-0759 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: NOS Cruise Control parts 73 and up?
John, can you take a pic of the diagram for me? I found a setup for my 71' in a junkyard 72' with the correct under dash switch and everything for inside the cab, but everything that was bolted up in the engine compartment was 73 + and I need to know what all I am missing. Thanks Trevor
Here's what I found for engine compartment pieces: ![]() ![]() ![]()
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Roadtrip!
![]() Join Date: Feb 2003
Any idea what the part number is for the complete unit?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Sorry,
I do not have the original box. I bought this about 8 years ago. There is a number on the instructions 547806 but that does not seem long enough. |
Anyone need an NOS turn signal Cruise control switch. I will seperate this. I am cleaning the garage and do not want to carry this over the winter.
John 425-417-0759 |
SWB 4x4 Collector
John, how much for everything but the cruise switch? Trying to figure out if this is for sure what I need or not. Thanks again for sending me the pics of the diagram as well. Trevor
SWB 4x4 Collector
Also, can you take a pic of the servo you used. Trevor
Trevor,
$20 shipped to you minus the switch. The servo was the same as my 69 with the only change I could see was the diameter of the nipple for the diameter of the vaccuum hose. I am not sure, but the servos look the same up to the point where they started three wires to the servo. I have the other servo, but was keeping it in the event I would need it. I will provide the nipple off the NOS servo as it will match the hose diameter if you want it. John |
Correction: the transducer is the same not the servo. Sorru
John PM me about the cruise control switch. I am not asking about a black style one that munts on the column, if thats what it is I'll pass. Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Rod,
The switch is black. You can see it in the fourth picture. |
