Old 09-02-2009, 11:44 PM   #1
reedwesd
Experts Please look over this setup.
I am sure this has been discussed A Lot but I have a 67 c10 stepside and have done a lot of research on lowing it and adding brakes. I would like to at some point add bags to the truck so I don’t want to spend a bunch of money on stuff that I will not be able to use later. I want to do a 4.5” front drop and a 5” in the rear. I do not want to cut my bed right now and plan on doing a bolt in notch. I also want to change it to 5x5 bolt pattern. Could you guys look over this set up and tell me what you would change.
Front Brake set up.
http://www.earlyclassic.com/catalog....version%20Kits
Rear Axel kit
http://www.performanceonline.com/sto...cat=450&page=2
Lowering Kit
http://www.classicperform.com/Store/...6372CSSK-D.htm
reedwesd is offline   Reply With Quote
Old 09-03-2009, 12:27 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Experts Please look over this setup.
I would recommend purchasing it all from ECE.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-03-2009, 12:37 AM   #3
jasonb72
PorterBuilt Man Crush
I second that, the customer support and service you get from ECE and Stan is far superior than the others.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 09-03-2009, 06:38 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Just make one big order from ECE. You won't be sorry. I've been ordering from them regularly for 15 years.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-03-2009, 09:06 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
x4 for ECE.
Also,... tell Stan or Mark you got their companies product suggestion on this website.
So many people use and love their products,... I'm trying to eventually get them onboard here as a member/vendor!
Keith
Convert to disc brakes.
Old 09-03-2009, 10:22 AM   #6
SCOTI
SCOTI's Avatar
x4 for ECE.
Your not the only one . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-03-2009, 10:28 AM   #7
bdydrp97s10
bdydrp97s10's Avatar
if you want front disk brakes.. look into a 73 up front crossmember. they are
5x5 and disk brake and they can be had for about $100 dollars.
and they bolt right into the frame.
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
bdydrp97s10 is offline   Reply With Quote
Old 09-03-2009, 02:54 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
reedwesd, I recently did this same install on my '69 (except kept 6-lug setup w/ 6" drop in the rear) and I ordered all my parts from ECE. While you can get a cheaper price from other vendors, their products and service as second to none.
I only had one issue (M/C cap was bent) and all it took was one call to Mark and I had a new one to me within a few days. Everything bolted together just as it should, and all the pieces were there the first time.
Also, as far as a notch in the rear, a notch will not be required for a 6" rear drop. We even left out the bump stops and I have yet to bottom out once. Here's a quick comparison shot for you on the 4.5/6 vs 4.5/5 spring drop. Now the wheel/tire size does play a role, but it will give you a good idea of what to expect.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-05-2009, 12:03 AM   #9
jasonb72
I thought I saw Stan on here the board some time back. I could have swore I talked to him about it when he joined up. Don't think their vendor status yet>
x4 for ECE.
Old 09-05-2009, 12:31 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
x4 for ECE.
Keep in mind that Porterbuilt Street Rods is a dealer for ECE. I take good care of all the board members, as they generate a large part of my business.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-05-2009, 12:43 PM   #11
SCOTI
SCOTI's Avatar
Some more than others . . ..... .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-05-2009, 01:22 PM   #12
C10Sim
C10Sim's Avatar
x2
1968 Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=321717
1959 Chevy Apache 3100 SWB Big Window
http://67-72chevytrucks.com/vboard/s...d.php?t=597069
C10Sim is offline   Reply With Quote
