09-04-2009, 08:22 AM | #1 |
Auto Linkage Question
Teeitup has a truck he is parting on the parts board. It has a TH350 transmission. The trans I found for my truck is a TH400. My question is are the linkages for the transmissions the same? If they are different, what are the differences? Does anyone have pics to compare the two?
-Scott- |
09-04-2009, 10:04 AM | #2 |
Re: Auto Linkage Question
not sure myself,bump for you
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
09-04-2009, 11:02 AM | #3 |
Moderator
I don't think there is a difference in the transmission linkage on the 2WD trucks, whether it is a 350 or a 400. IIRC, the linkage is different if you have a 4WD truck. Someone will post a pic to verify, I am sure.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-04-2009, 12:07 PM | #4 |
The pivot point on the frame is different and the 350 will not line up with the 400 trans unless you drill new holes in the frame. The rod and the connection between the trans and pivot are the same. The 4x4 uses a different pivot point and a different rod to connect.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
09-04-2009, 11:08 PM | #5 |
Always on the hunt...
Here are some side by side comparison pics for you to check out.
