Old 09-05-2009, 07:47 PM   #476
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Glock's new project: "Fred"
Ahhh, I have my shop back!!!
The two bundles of wires I'm holding is all that will remain under the hood. The bundle running over the brake booster is left over from the TBI stuff, and I will keep a couple if the are 12v battery and ignition, the rest will probably just get cut short and capped and hidden in the split loom.
The right bundle is to the front light harness, the left bundle is to the starter, oil and temp senders, AC, and a couple other things I'm not sure of right now! I'm pooped!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-05-2009, 08:33 PM   #477
SBTork
Garage wrench
SBTork's Avatar
looking great man. Looks like it will be a busy holiday weekend for you.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 09-05-2009, 11:34 PM   #478
menace121978
menace121978's Avatar
looks great Bob... looks like you got a lot done now get some rest so you can hit it hard in the morning!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-06-2009, 01:29 PM   #479
joe231
joe231's Avatar
Right on!!
I love your shop BTW
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-06-2009, 04:55 PM   #480
glock35ipsc
Thanks Joe!
Got going about 8 this morning, I slept in!
Got the trans pulled out, then got both gas tanks pulled along with ALL fuel lines, return lines, and switch valve. Then pushed Fred back outside to give him one last pressure bath. Cleaned up a few other parts like the trans crossmenber and some misc brackets. After a good drip dry while I cleaned up the shop, my son helped me get him back in.
Then I got the mod done to the engine stand. This will be easy to do in the future once I get the motor mount located and drilled. I have a template made for the piece to weld in, and I'll make one that references the original mount holes to the new holes. Easy.
Then I modded the adapter plate by drilling two new holes and tapping them. Then I cut the front ear off that had the interfering hole. On the clam shells, there is a triangle shaped part that is pressed into it between the three holes that has to be cut out so it sits flush against the adapter plates. Got that cut out, and had to clearance the clam shell in two places, very minor, to clear one bolt head and to be sure I had ample clearance to the AC bracket.
** NOTE - When doing this, the upper rear clam shell bolt will be VERY close to a web on the block. I added a lock and flat washer to be sure I had plenty of room, as I didn't have a shorter 3/8" bolt.
The engine is ready to be bolted to the trans and be set in. Once I get it centered up, I can get the trans crossmember set in place, tack weld the motor mount to the stand, then pull everything out. Then I can drill the holes in the stand and break the tacks off. I'll make the template, then hit it with some paint and bolt it back on.
Getting close!!!!
Oh, the u-joints are the original ones!! 211,000 miles!! I think I know where that minor vibration at certain speeds was coming from now.
And the fuel tanks are pretty dirty inside, and the return line drained BROWN. May have been where the surge was coming from? The fuel that drained out of the fuel filter was brown too.
Bob
Old 09-06-2009, 04:57 PM   #481
glock35ipsc
More...
Bob
Old 09-06-2009, 05:00 PM   #482
glock35ipsc
Here you can see where the upper rear 3/8" bolt comes close to the block web. Just be sure to use a washer on a short bolt. Finger tighten first to be sure.
I'm done for today. It's my boy's 9th birthday, so we are getting ready to head to town then to Grandma and Grandpas!
Tomorrow the 5.3 gets set in it's new home!!!!
Bob
Old 09-06-2009, 08:56 PM   #483
menace121978
awesome! I UNDERSTAND NOW!! i guess i'm a visual person
"Dennis the Menace"
Old 09-06-2009, 10:48 PM   #484
N2TRUX
Happy to be here
N2TRUX's Avatar
Nice progress Bob...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-07-2009, 12:56 AM   #485
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Bob, I just have to say it since no body else will. YOU SUCK!
Sorry I had to. Good job on Fred. I can't wait to see him up and running...or is that going to be up and sprinting?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-07-2009, 01:19 AM   #486
hessian18
Gen III Power
hessian18's Avatar
I can go with that !! X 2 ahahaha
All I can say is soon, I have a truck lined up
Looking forward to more updates.
Bob
---Bob---
'81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon...
hessian18 is offline   Reply With Quote
Old 09-07-2009, 07:54 AM   #487
JohnC
JohnC's Avatar
Looks awesome man! You are making some serious headway on Fred. Keep the momentum going, and heck you might have this swap done before Fall gets here.
JohnC is offline   Reply With Quote
Old 09-07-2009, 10:23 AM   #488
glock35ipsc
Thanks guys! (except maybe for Gerald )
I'm setting a lofty goal for myself..... have Fred running for our September BBQ/cruise on the 27th. I may be stretching it a bit, and he may not be 100% completed, but it's the goal for now.
After coffee is done brewing, I'm heading out to set the engine and trans in.
Bob
Old 09-07-2009, 12:56 PM   #489
glock35ipsc
WOOOOOOOOHOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!
Engine mount mod worked PERFECT, NO mods needed for the trans cross member other than drilling 4 easy holes. Engine is perfectly level side-to-side, and I have 3.5* of angle back. Truck manifolds will work with about a quarter sized piece to be notched from the frame. Drive shaft fits perfect. Even the shifter linkage is in the right place. Passenger side exhaust will hook up the the existing pipe easily. Drivers side will need the pipe cut from the flange and rotated to get the right angle, but will be fairly easy too.
I'm getting a little nervous.... things are going TOO good so far!
Weeks of planning just paid off!!!!!
Bob
Old 09-07-2009, 01:23 PM   #490
menace121978
you sure work fast! looks like it belongs in there
i sure am glad its going so smooth!!!!!!!!!!
"Dennis the Menace"
Old 09-07-2009, 02:16 PM   #491
nlped
nlped's Avatar
^^^Yep! I'm sure glad too. Makes the task a lot less daunting with all these pics and info. Now if it will just quit raining for a few days so my damn concrete can get started
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-07-2009, 02:37 PM   #492
JohnC
JohnC's Avatar
Congrats Bob!!!!
The reason it went so easy is the helper you had. Give that girl a cookie!
Man this is should be a sticky thread for sure when it comes to LSX conversion.
Old 09-07-2009, 02:50 PM   #493
glock35ipsc
When it is all done and running, I am going to do a huge post with step by step and pics, and make a FAQ out of it.
Putting on the harness right now, have the engine bay painted, and getting ready to put it back in.
Oh, I just remembered that I forgot to test fit the AC. Oh well, at least that's in a place that I can get to easy to do whatever I might need to.
Lunch time!
Bob
Old 09-07-2009, 02:53 PM   #494
JohnC
JohnC's Avatar
Your a man on a mission!!! Keep it up man.
Old 09-07-2009, 06:05 PM   #495
Very Nice! Making me think of a square body again.
Old 09-07-2009, 06:09 PM   #496
LiveAnimals
LiveAnimals's Avatar
Well done, I cant wait to see the finished project
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 09-07-2009, 06:32 PM   #497
Rollinsqrbdy
Rollinsqrbdy's Avatar
wow that looks really good.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 09-07-2009, 06:43 PM   #498
lolife99
67-72 parts collector,…
lolife99's Avatar
Glock,...
did you happen to make some "templates" of your new engine plates?
Maybe some for sale in the near future?
Keith
Convert to disc brakes.
Old 09-07-2009, 09:31 PM   #499
glock35ipsc
Too tired for details tonight, I'll catch up with everyone tomorrow.
I don't want to see the inside of my shop until Wednesday!!
This weekend's progress was HUGE!!!!
I'll leave y'all with these, more coming tomorrow. G'nite!
Bob
Old 09-07-2009, 09:33 PM   #500
glock35ipsc
Glock,...
Yes, and yes.
Bob
