Old 09-04-2009, 02:15 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
yet another rear gear question...longhorn.
i have always asumed that i had a 3.73 rear end. i followed the instrutions found in this post. about turning the tire and counting how many times the driveline turns...
http://67-72chevytrucks.com/vboard/s...ight=rear+gear
my results say its a 4.11. it could be right i guess, but this truck has never be able to spin the tires much, and its a bit of a dog off the start. the power of the motor should be enough.. on the high way i run 70mph at 3000 rpm. 16 inch rims. Tire size 235/85/r16.
does this sound like a 411 to you? btw its an open axel.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 09-04-2009, 02:21 PM   #2
rwolf9653
more ideas than money
rwolf9653's Avatar
Re: yet another rear gear question...longhorn.
What trans??
It is possible to have 4:11, but more likely that you have 3:73's.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 09-04-2009, 02:33 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
I have 4.11 gears and turn 3000 rpm at 70 mph. Tires are 265/70R16. Is your Longhorn a 3/4 ton?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-04-2009, 02:55 PM   #4
mtdave2
mtdave2's Avatar
ya 72 c20, th350. 350 motor
69 k10 Suburban
Old 09-04-2009, 04:16 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
dave, with as original as your truck was when you got it, it is very safe to say the rear has never been opened.
With that being said, 4.10 was the tallest gear you could ever get stock. 4.10, 4.57, and 5.13 (I think the last one was only on trucks with the dual rear wheel option)
Being a small block and auto, the 4.10 was the standard gearset, so since nothing was optioned otherwise, the truck was all original when you got it, and the spin the wheel test agreed with it all.... you have a 4.10 gear.
Old 09-07-2009, 12:00 PM   #6
mtdave2
mtdave2's Avatar
i wonder why is not better off the line? perhaps im just picky lol.
69 k10 Suburban
Old 09-07-2009, 02:53 PM   #7
Skirkpat
Skirkpat's Avatar
I would not blame the rear end for the lack of acceleration, pop the hood and start placing blame there, Remember these are HEAVY, and a stock small block is not a powerhouse by any stretch of the imagination.
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 09-07-2009, 03:14 PM   #8
Boog
laying low
Boog's Avatar
Be a good time to look into the condition of the engine. Compression test and tuneup maybe. Look at the advance mechanism in the distributor. It could be the mech advance is siezed up and that will make it sluggish and thirsty. Also the vacumn advance may be bad. Or it may only need some new plugs, wires and cap.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-07-2009, 03:46 PM   #9
mtdave2
mtdave2's Avatar
http://67-72chevytrucks.com/vboard/s...ighlight=heads
motor is fine, i think its just heavy..lol
69 k10 Suburban
