Mean Green
My plan is to build a 4L80E so i can run a low gear ratio for track, but have ability to drive to the coast, and show's.
Mike Last edited by 68 C-10 KID; 09-08-2009 at 12:41 AM. Reason: Better wording and alterd ?'s |
#2 | |
Re: ? on building a 4L80E
See red
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Mean Green
1. Is there a year that i need to look for? It's going behind 406 sbc90-96 supply and return close together
2. Who's controller to use or do I need one with full manual valve body?No controllers needed for manual valve body 3. Who's performance rebuild kit Should I go with? I'm going W/ transtar Hp kit w/ 34 element sprag and FWD billet hub. (most complete) 4. Who would make a low slip converter? 5. How much do I need to shorten drive line? 6. What drive line yolk do I need? I currently run a 3/4 ton BBC, TH400 drive lineTH 400 will work 7. What needs to be done for trans cross member? 8. How much is reasonable price to pick one up? 9. @ this time should I convert to one piece drive line? I'm looking for 60-67 3/4 ton with 3 speed should be around 3 1/2" dia This is some of the info I picked up so far. Dry weight, the 4l80E is only 40lbs more than TH400. Some company's offer a tail shaft now that has mech. speed o. The Th400 speed o slides right over shaft. |
| Bookmarks |
