Vacuum Help ??
Who has a pic of a vacuum motor
or am I miss understanding it by another name? and where is it ? http://www.unlimited2u.com/1chevy/vachelp/vacuum.htm anyone have a good readable diagram on vacumn locations for the engine compartment ?? Last edited by Nvbowtie; 04-08-2003 at 03:31 PM. |
The vacuum motor should be on the top of the air intake snorkel tube. Just hook it up to a full vacuum source.
Ultimate Diesel Dude
Vacuum motor? I'm not sure what you're talking about. What does it do?
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
My project was engine less and wont have a std air intake snorkle, so I understand that part but where is a full vacuum source?
Since it came with no engine and alot of stuff gone or not hooked up, I was following the emissions diagram on the radiator support, thats where I saw the term "Vacuum motor". That thing is a crossed mess of tubing, which most was deleted when I removed the dual fuel canisters, now just trying to figure out what vacuum lines that has to be there when the engine is ready. I am trying to get my firewall cleaned up, and trying to plan any needed vacuum lines. (see pic web page below) http://www.unlimited2u.com/1chevy/vachelp/vacuum.htm All I know now, is I need a vac source for the following: 1. Power Brake, Modulator on TH350, Holley 650, and distrubtor. 2. Air controls under the dash, (not that far yet, but will be soon!) Where do these vac suppies come from ? Am I missing something ? ** Discontinued items: Cruise control, Fuel Canisters.... sorry to be lame here, but it's my first crack at engine bay stuff, I was use to dealing with fabs and body work on my other trucks, my friend that no longer lives here was my engine hookup expert so I think sometimes I am in deep sh!t, then it turns out I just learned somthing new and it was not all that hard to do.... Bill Last edited by Nvbowtie; 04-08-2003 at 03:33 PM. |
#5 | |
as far as the brake booster it hooks up to the intake manifold.... there should be afitting there (a big one) the trans should hook-up there also......the dist. hooks up to a ported vac port on the carb (makes morevacuum as r's go up)....other wise you will be running full advance on dist all the time (not good) the air controlls under the dash should hook up to the intake as well full vac...any other ports on carb...are for switches etc... this fitting on the intake should have about 3 or more ports if not make it so.....any more questions just ask....mark |
| Bookmarks |
