Motor choice?
What are your personal likes and dislikes of engime swaps. What motros do you guys like to use and why?
What are your ideal engines? What are your fantasy engines? Building my 54 pickup now and the truck already has a 4.3 s10 carbed motor in it. Not sure if I should keep it. I would love to put a TT big block in it, but not really practical, plus the wife plans to drive the truck. If I keep the 4.3 I plan to turbo it in a year or so. Will the stock 4.3 be powerful enough to move the truck? |
and a few others
Re: Motor choice?
There are several builds here that have chosen to keep the 4.3 and a couple with the 2.8 and they seem to be happy with them. Kinda keeping it simple.
I'm gonna be starting my 53 / S-10 swap in about a week, but I chose to go with a centerbolt head 350 (for the semi-modern look) and a 700r4. Just my personal preference, I want that v8 sound. ![]()
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Re: Motor choice?
I'm a 283/327 fan. But I upgraded to a 350 for my truck because I wanted more low end torque than a winder. I'd love to build a salt flat roadster with a high winding 283 and high rearend ratio.
#4 | |
Re: Motor choice?
Mine had a SBC in it when I got it and is probably the basic choice because of ease of getting parts and the large number of hints, how-to's, parts to make it work. My son is planning on putting a Caddy 500/TH400 in his 51 Suburban. It really boils down to how much you want to spend, what you have around you, how "different" you want to be, etc. If I had a choice and money no object, I've always wanted to put a 1970's 6.9L Benz in something (286HP/400ftlb torque, 12500 miles between oil changes, 50000 between maintenance). For a more modern powertrain, I think 90's Lexus V8's look great and have seen them in some rods. |
Re: Motor choice?
If your wanting a easy driving fast truck, you need to look into the LS swap.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
Re: Motor choice?
I have thought of the LS1, may be an option.
Also thought about doing a police package lt1 motor or a chevy impala ss motor. How do you guys like the LT1 motors? Cheap enough. Want to build the truck on somewhat of a budget. Seen complete lt1 swaps for $1000 and LS1 swaps for $3500 and up Always been into VW's. Used to have a vr6 with a GT35/40 pushing 480whp at 462ft of tq. Toyed around with that idea of stuffing a vw motor in, but want to keep it kind of original. Future plans are to do a charger or turbo on it. Would like to keep it around 3-400 horse. Drivable and powerful but not ripping the tires on every accelaration. |
Re: Motor choice?
I think LS is the way to go thats what i am doing. you can get a 5.3 truck motor with a harness and computer for probably less than 1 K. very good drivability and 300hp stock, much better than a LT1. they also respond very well to mods. with a cam swap headers and tune mine should be close to 400 hp.
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
Re: Motor choice?
a 4.3 with a pro charger or turbo on it is not bad at all, and in my opinion it definitely has the "different" factor with one of those on there.
Price has a lot to do with my decisions. I wanted a 350 but settled for a 305. To be honest I wouldnt ever want to take it down a drag strip anyway so whats the difference for a cruiser?
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! |
#9 | |
Cradle Robber
Re: Motor choice?
"The problem with the world is that everyone is a few drinks behind." Humphrey Bogart "Hippies.They're everywhere.They wanna save the earth,but all they do is smoke pot and smell bad."Eric Cartman "Think about how stupid the average person is,and realize half of them are stupider than that."George Carlin |
Re: Motor choice?
i put an lt1 from a 96 or 97 vette in my '38 chrylser. Yeah its a good motor, but an ls is still the way to go IMO. next rod i build is getting a ls1.
Re: Motor choice?
Look into the 5.3, 6.0 ls motors. I might be a little bias because Im putting a 5.3 in my 59. I paid 850 for the running engine and all the wiring. With this you can use any style trans as well with an adapting spacer.
Re: Motor choice?
i have a 350 SBC and a 390 Cadillac engine to pick not sure which one to use yet
Re: Motor choice?
i found a 5.3 vortec motor with trans wiring computer etc.. for $600. Good, bad? Sounds very reasonable. How difficult is this swap into a 85 s10 chassis? v8 motor mounts?
Re: Motor choice?
If its in running condition then it sounds like somthing to buy before anyone else get the chance. Motor mounts can be made fairly simple so you can put the engine where ever you want, theres a diagram for the plate that bolts to the engine, just use the 4 that make a rectangle and overlook the 2 that form the top of the triangle of the sbc mount.
Your gonna have to most likely have the ecm reprogrammed which will will run a couple hundred dollars on average and your gona need to upgrade the fuel system to accomodate for the 55-60+ psi fuel pump that you'll be installing. |
#15 |
Re: Motor choice?
I love my LT1 but that was a personal and financial choice at the time. I had the luxury for having a friend that's swapped at least a dozen of these motors (94-96) as well as building these up to take over 500hp and the used Impala SS motor cost me $500 complete with wiring harness and ECM. By the way the Corvette 94-96 LT1 has 4 bolt mains.
If it wasn't for my buddy and his laptop to program my ECM, I would have gone old school with a carburator. The cost of rebuilding a 94-96 LT1 is very expensive too if you pickup a high miler. Up here in Canada the Opti-Spark distributor is about $700 and the Water pump is about $500, never mind the $300 for injectors etc, etc. I was lucky to buy my parts out of the US from Dallas Salbaugh........cheap, cheap, cheap. I have never looked into what other parts are required to install an LS1 but that would be the deciding factor to me. LS1 vs a Crate Motor = Whats the final cost? |
#16 |
Re: Motor choice?
you dont have to go with the LS1, they are still overpriced. the 5.3 truck motor can make as much power as the LS1. it is basicly a iron block LS1 with a little smaller bore, and the truck intake makes more low end power than the LS1 intake. I built a LT1 in my 93 Vette, very expensive to build.
cost to swap a 5.3 LS motor cost of motor with harness and PCM 1K max rework harness for stand alone operation and reprogram PCM $350 new fuel pump and corvette filter with built in regulator $150 engine swap motor mount conversion brackets $100 I may have left out a few small items but you wont find a crate motor with 300 hp and this fuel mileage and driveability for $1600. and if the Government ever comes down on us about our old vehicles this one will pass emission testing. something to think about.
#17 |
Re: Motor choice?
Very true to think about with the LT1. Did not realize they were so expensive. Thank you guys for your patience and advise. I am still very new to the american car world. The last american car I had was a 1988 jeep cherokee limited. I hated it. a real POS.
I will check into the 5.3 LS motor. Any years better than others? |
#18 | |
Re: Motor choice?
#19 |
Re: Motor choice?
I am putting my 54 GMC on an S10 chassis and decided to leave the vortec 4.3 in it... Makes good power, gets good MPG and has a great tranny 4L60E behind it... Im a big fan of fuel injection... I have a tune port in my 68...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
#20 |
Re: Motor choice?
C10, thank you for posting that pic and description. Do you have any other work to the motor besides an intake. What year is the motor from?
#21 |
Re: Motor choice?
sorry but for the 4.3 or the 5.7?
#22 |
Re: Motor choice?
c10,
Both motors would be helpful. Thank you, andrew |
#23 |
Re: Motor choice?
4.3 is a 97 and mostly stock. Cat will be removed and I sent the computer out and had it flashed for a little more HP..
5.7 is out of an 86 Vette and has the high flow intake runners, comp cams camshaft, computer chip, headers and no egr stuff.. Honestly its a dog but its reliable and looks good! ![]()
#24 |
Re: Motor choice?
thank you very much!
