Old 09-10-2009, 07:52 AM   #276
Keith Seymore
Keith Seymore's Avatar
Re: Intro from an old Assembly Plant guy
Ok - so here's the point where you find out they are not "exactly" the same....apparently the transfer case shift lever is "coarse" thread and the transmission shift lever is "fine" thread Nothing that a couple minutes with a 7/16 fine thread tap couldn't fix:
And here we are, back in business:
Total time investment: about 15 minutes; dollar investment of about $3.00 (for shipping).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-10-2009, 07:59 AM   #277
Keith Seymore
Originally Posted by bumslie75 View Post
Wonder what he is going to do with the engine
Originally Posted by Keith Seymore View Post
Nothin. Seems to run good...
I guess that's not entirely true: I noticed the engine seemed to run "too cool", that is, the needle on the temp gage wouldn't come up to the first mark. Probably running about 140 degrees, and I was concerned that wasn't warm enough to burn all the condensate out of the motor oil plus - with winter coming - I'm going to want some heat in the cab!
So I did replace the thermostat with a new 180 deg stat; that seemed to help, as the needle is now coming up to the first mark on the gage. I'm wondering if that earlier stat (marked as a 180) had some problems.
K
1979-1986
1986 - 2019
Old 09-10-2009, 08:02 AM   #278
Thealien
Thealien's Avatar
Great intro/thread. Rep point given!
Thealien is online now   Reply With Quote
Old 09-10-2009, 12:02 PM   #279
87Bob
K
I had heard that there are some problems with sending units reading cold when actually the engine is running at the right temp. The best way to check I'm told is to use an infared gun and check the temp at the thermostat housing. Then you know if it is the sender or the thermostat. As the sender gets hot the resistance is supposed to fall that is why you can check the gage by shorting out the wire to ground and the gage should read full hot.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 09-10-2009, 12:04 PM   #280
Keith Seymore
Thanks; I hadn't heard that. I will check it out (...although I have some degree of confidence it may have been the thermostat since changing it seems to have made a difference).
K
1979-1986
1986 - 2019
Old 09-12-2009, 08:37 AM   #281
dan76
As I recall from HS physics, as an electrical component rises in temp, its' electrical resistance increases.
dan76 is offline   Reply With Quote
Old 09-12-2009, 09:41 AM   #282
joe231
joe231's Avatar
that is true with most, but not all.....
a positive temperature coefficient is as you described, temperature rises=resistance rises (examples include: incandescent bulbs and motor windings)
a negative temperature coefficient is just the opposite, temperature rises=resistance falls (examples include: thermistors and semi-conductors)
I am not sure if the temperature coefficient of a sending unit is positive or negative though....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-14-2009, 07:12 AM   #283
Keith Seymore
9/12 & 9/13 2009 Edition:
1) Finished the door opening on the driver's side (paint, added the new weatherstrip and door sill plate)
2) Painted the pickup box (it's about 98% done; pics to come later)
3) Started on the inside of the doors:
1979-1986
1986 - 2019
Old 09-14-2009, 08:36 AM   #284
rod86
great southern land
rod86's Avatar
lookin good
rod
86 chevy c10 silverado
rod86 is offline   Reply With Quote
Old 09-14-2009, 05:17 PM   #285
dan76
Keith:
Where did you pickup the vinyl floor covering? I've always liked it better than carpeting...as long as there was a good thick mat installed beneath.
Old 09-15-2009, 11:58 AM   #286
Keith Seymore
Keith:
From Site member/vendor Captkaos:
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD)
Captkaos Customs
73-87chevytrucks.com
It's a good, thick vinyl and comes with the "shoddy" insulation that goes underneath.
1979-1986
1986 - 2019
Old 09-15-2009, 12:01 PM   #287
Keith Seymore
These are the inserts that go in the door trim panels. This is the same technique I used for the dash panel insert, discussed previously:
1979-1986
1986 - 2019
Old 09-15-2009, 12:02 PM   #288
Keith Seymore
Some people have a "green thumb"; I have a "gray" thumb!
(lol)
1979-1986
1986 - 2019
Old 09-15-2009, 12:29 PM   #289
menace121978
menace121978's Avatar
ive been known to have one of those myself!
looks great keith! almost done!!
what will be next after the doors??
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-15-2009, 02:18 PM   #290
Keith Seymore
Nothing! After the doors, I'll touch up the edges of bed a little bit and then it's done!!
(lol)
Then I'll just drive it!!
K
5-8-2009, 2:35 pm
I hope to get it repainted over the GM shutdown period in July and then I intend to drive it.
K
1979-1986
1986 - 2019
Old 09-15-2009, 02:33 PM   #291
JohnC
JohnC's Avatar
You think you'll be done.
Looks good man, and you will have time to enjoy it before winter comes.
JohnC is offline   Reply With Quote
Old 09-15-2009, 03:42 PM   #292
Keith Seymore
No, no - I have to be done. I've got other stuff I'm supposed to be working on!
Seriously, I had one project one time that was actually DONE. I redid a Farmall tractor and once it was refurbished I never had to work on it again.
It was a very cool feeling (...very different from having a race car. Race cars are never done...):
1979-1986
1986 - 2019
Old 09-15-2009, 04:00 PM   #293
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
I have a 84" C-10 swb that was built in flint!!!! man ur story is soooo cool!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 09-15-2009, 04:19 PM   #294
JohnC
JohnC's Avatar
That's a cool tractor. Do you still have it? If so that would be a sweet photo with your swb pulling your tractor.
Old 09-16-2009, 07:48 AM   #295
Keith Seymore
What color? I probably remember it (...unless it was built on first shift) - lol!
No - it stayed with the house when we sold it. The tractor was the "deal maker" - the buyer and I were a few thousand apart on the price of the house. He said "...I'll pay your price if you throw in the big red tractor and the 'broken' tractor...".
I said "...you'll have to be more specific about which 'broken tractor' you are talking about!"
1979-1986
1986 - 2019
Old 09-16-2009, 08:39 AM   #296
JohnC
JohnC's Avatar
Old 09-16-2009, 12:28 PM   #297
Mr.Scary
Mr.Scary's Avatar
Its blue i would post pics but i dont know how 2 resize that pics 2 post them?????????
Old 09-16-2009, 12:51 PM   #298
joe231
joe231's Avatar
those look nice!!
I guess I need to go back and find the previously discussed, discussion
CHEVY ONLY
Old 09-16-2009, 02:19 PM   #299
Keith Seymore
I was teasin'....we built about three and a half million trucks during the 7 years that I was there.
It's unlikely I would remember it (unless it was one that got dropped, or smashed or something...)
1979-1986
1986 - 2019
Old 09-16-2009, 02:24 PM   #300
Keith Seymore
The funniest thing was: the tractor he was talking about wasn't broken...
1979-1986
1986 - 2019
