Old 09-12-2009, 11:14 AM   #551
menace121978
menace121978's Avatar
Re: Glock's new project: "Fred"
i was just noticing you ended up going w/ just 1 filter/regulator. and how far up the frame rail to the engine is going to be high psi. rubber hose? man that looks a whole lot simpler than i imagined! 1 more question, are you going to use rubber hose to connect to the sending unit and hard line for the passenger side also? okay i lied 1 more, how many 37* flares did you have to make going with mostly high psi hose? i guess you had to make 2 on just the trans cooler lines alone...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-12-2009, 05:45 PM   #552
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Originally Posted by menace121978 View Post
i was just noticing you ended up going w/ just 1 filter/regulator. #1and how far up the frame rail to the engine is going to be high psi. rubber hose? man that looks a whole lot simpler than i imagined! 1 more question, #2are you going to use rubber hose to connect to the sending unit and hard line for the passenger side also? okay i lied 1 more, #3how many 37* flares did you have to make going with mostly high psi hose? i guess you had to make 2 on just the trans cooler lines alone...
#1 High PSI hose all the way to the engine, really isn't that far.
#2 Yes, rubber from the pass side SU to the valve, and I used the OEM hard lines to run across from the drivers side.
#3 Yup, 2 on the cooler lines, and 1 on the output side of the filter.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-12-2009, 05:51 PM   #553
glock35ipsc
Whew, busy day!! Got a TON done again.
I need to get in the shower and head to town, but quick overview:
- Exhaust hooked up
- Driveshaft in
- Rad support on, grill on, radiator in, rad hoses on
- Almost ALL wiring done, cruise hooked up, fuse block and PCM relay installed and wired. I just need to wire the fuel pump relay, and modify then mount the pedal, and crimp a ring terminal to the starter end of the battery cable.
If it wasn't for needing the correct AN fittings for the trans cooler, I could fire it tomorrow!!!!!!!
7 total working days so far!!!!!!
Bob
Old 09-12-2009, 05:55 PM   #554
joe231
joe231's Avatar
Wow!!!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-12-2009, 05:59 PM   #555
menace121978
sweet! i was thinking you would have to use steel braided lines along with the -an fittings.... much simplier, cheaper, and easier!!
damn your almost done man!!!!!!!! i cant wait for the 1st start-up...
"Dennis the Menace"
Old 09-12-2009, 06:01 PM   #556
menace121978
and hey wait just a minute here!! check out that grille! awesome!!
"Dennis the Menace"
Old 09-12-2009, 06:08 PM   #557
glock35ipsc
Yeah, Fred is a little confused as to his identity!
As for the fuel line I used (the blue line), it is from Summit, and the AN fittings used for it are Summit's "Snap Tite" or something like that. Rated for up to 250 psi. Simply push the fitting on the hose. And they WILL NOT pull off! I tried!
Bob
Old 09-12-2009, 06:29 PM   #558
JohnC
JohnC's Avatar
I was thinking the same thing. He was trying to sneak that one in on us.
JohnC is offline   Reply With Quote
Old 09-12-2009, 06:31 PM   #559
menace121978
man, i cant stop looking at those pics! your making this swap look like a piece of cake Bob...
btw great info on the fuel system!
John, i actually had to stop and watch his avatar for a sec.
"Dennis the Menace"
Old 09-12-2009, 06:52 PM   #560
JohnC
JohnC's Avatar
Man you need to get back to work on your truck so little things like that don't slip by you.
Old 09-12-2009, 09:59 PM   #561
glock35ipsc
I'm in a pickle as to what I should do about the fans. The stock e-fans won't work as-is, too wide. I could cut them and make them "temporarily" fit, but they are in great shape and I could probably sell them. But my funds are running low for the month. On top of that, I need to buy one O2 sensor. I think Rancho broke one or something, because the y-pipe they sent had 1 front O2 sensor and 3 rears installed into it. A new front is $103.
I went and walked around Fred a couple times making a list of what I still need to do. I still have a long list, but they are all little things that shouldn't take much time. Like I forgot about the fan relays. I'm still thinking I'll make it for our cruise the 27th though.
So I'm gonna hit the bone yards next Saturday for fans and an O2 sensor, hopefully I can find both. That will help in the $$$ department.
Bob
Old 09-12-2009, 10:03 PM   #562
menace121978
Bob, you should call rancho and tell them the progress (for the warranty) and mention the o2 sensor. i know they will send ya a new one so you can save a few bucks...
and i take it there was too much modifaction needed to get the '06 rad. to work??
"Dennis the Menace"
Old 09-12-2009, 10:03 PM   #563
SBTork
Garage wrench
SBTork's Avatar
On some of the other truck forums you should be able to get over $100 for those stock fans. That should help. Keep plugging away man, you're really close.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 09-12-2009, 10:08 PM   #564
glock35ipsc
True, I should call them on Monday. The rad actually would have been easy to make work, the problem was with the lines off of the AC condenser. They curve around the right tank, and they were too tight to bend without pinching them off.
Bob
Old 09-12-2009, 11:36 PM   #565
menace121978
another idea just to throw it out there... is the shaft on the water pump threaded?
"Dennis the Menace"
Old 09-12-2009, 11:41 PM   #566
glock35ipsc
LOL, yup, and it did cross my mind. Cheaper to grab at the bone yard too. I still want e-fans, but I'm hearing ya!
Bob
Old 09-12-2009, 11:59 PM   #567
menace121978
same page!!
dang whats a guy got to do to get some rep around here... read minds!! jeez
"Dennis the Menace"
Old 09-13-2009, 12:19 AM   #568
glock35ipsc
Given!
Bob
Old 09-13-2009, 12:27 AM   #569
menace121978
thanks Bob!
"Dennis the Menace"
Old 09-13-2009, 01:05 AM   #570
Codys87
Codys87's Avatar
Your build is going awesome and like others have said your making it look easy!
What did you do for the coolant bypass on the front of the heads?
85 SWB 6.0 swap/heads/cam/pistons/headers/4L60E/3.73 posi/one piece windows/working towards air bags
04 Avalanche/9 inch lift/wheels 20x12 with 35 inch tires
Codys87 is offline   Reply With Quote
Old 09-13-2009, 11:04 AM   #571
glock35ipsc
Thanks! Weeks of planning, and noting what others have done both on here and on a bunch other forums, what worked and what didn't work for them, and putting all that in a three ring binder, made this seem easy.
There is a heater hose that runs to a nipple on the original radiator in the 85, so I will put a very short piece of heater hose on there with a 90* brass nipple and run it to that point. It can follow the upper radiator hose back to the engine. I kept all the clamps off the original rad hoses (which I am using) and there are a few that clamp around the rad hose and has a place for a smaller hose to clamp on.
Another option I have that looks a little cleaner, but runs about $35 from the Jags That Run site, is a nice piece that splices in the upper rad hose. I like it because it mounts it as high as possible in the system, and it has a petcock that is used to bleed air. I'll run it to the radiator for now to save $$$ and get it running, but I may try one of these later.
http://www.jagsthatrun.com/Pages/Par...g_LSI-tee.html
Bob
Old 09-13-2009, 01:13 PM   #572
rongstad
Future: 86 on GenIV power!
Great thread!!! You're really making progress..... cant wait to start on mine...
rongstad is offline   Reply With Quote
Old 09-13-2009, 02:23 PM   #573
Red84C10
Nice work your making me jealous.
Red84C10 is offline   Reply With Quote
Old 09-13-2009, 07:28 PM   #574
nlped
nlped's Avatar
Holly Hell, Batman! You made a ton of progress this weekend. I can't wait for this to run...probably not as much as you though
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-13-2009, 09:56 PM   #575
glock35ipsc
Hehe, yes I did!
I got ALL the electrical, with the exception of the e-fans, done today. Everything!! I can hit the key and bump the engine over!
Gauge cluster is re-pinned and installed. Everything seems to work on it.
I cut the pedal off the electric pedal, and cut the OEM pedal off and welded it on the electric unit. This make the pedal look stock when standing at the door.
I had an old stock intake system for a truck I use to have, so it will get used for now until I get my new budget next month. I cut the huge goiter looking thing off that hangs off the bottom, and cut and fit a piece of metal to fit the hole. A little RTV and some screws and I have a rednecked air intake setup for now. I just need to pick up a filter, then make a little bracket to hold it tight and keep if from flopping around.
I think I did more than just what I typed, but I am really tired right now.
All I really need to fire it right now is the tranny cooler fittings, a fan or e-fans, and hook up a fuel tank. I may go ahead and order the fittings I need, even though I send that others back to exchange. That way I can have them before the end of the week, then I can just send the others back for a refund. Summit rocks in that department.
Bob
