Old 09-12-2009, 11:00 PM   #1
hemihead
hemihead's Avatar
Stainless bed strips - over or under?
Test fitting my new wood bed before the bed goes in for paint....where the strips run into the wheel wells, are the strips supposed to go between the wood and the wheel well? Looks like it should but to get the wheel well to sit flush, one will have to grind some of the strip away.....is this correct?
The strip would not look right over top so assume this is wrong.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
Old 09-12-2009, 11:13 PM   #2
Rack Man
Re: Stainless bed strips - over or under?
UNDER...Factory ones were a little thinner and sat deeper into the wood grooves, so they sat nearly perfectly flush!
I just finished mine and I wasn't sure what to do either...I wanted to grind the tops down but I was worried about the integrity of the strip...from all the pics I searched it appeared that most didn't sit exactly flush in that spot, so I figured they just lived with it....so thats what I did......Maybe I should have just ground em down?...One quick tip: Double & triple check the squareness of the bed when your test fitting and marking holes to be drilled in the wood!
Not a perfect pic of that area...but you can see that it doesn't stand out too bad!.....
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 09-13-2009, 12:50 AM   #3
hemihead
hemihead's Avatar
Thats what I figured. My new wheel wells also aren't perfect...the front side bolt holes don't line up with the bed strip holes...off about a 1/2". Been looking at this new problem and doesn't look like much I can do with it
2009 Acura MDX
Old 09-13-2009, 01:37 AM   #4
Green Machine
Green Machine's Avatar
Doing same thing here, going to have a little dimple in the wheel tubs, but should still be OK.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
