Changing rearends
I'm finally changing my 69 Fleetside from 6 lugs to 5 lugs. It's a 1/2 ton with coil springs.
Do I need to replace the U-bolts on the trailing arms or can I just use the old ones? If I need to replace them, where do you recommend buying them?
Robert Member 1532 |
![]() Join Date: Nov 2006
Re: Changing rearends
Rather than going to all that trouble you could just pull your axle shafts out and send them to moser eng. In portland indiana and have them re-drilled to 5x5 bolt pattern. There very inexpensive to redrill, use your old wheel studs too. Sure would save alot of time and money. Then use 5 lug drums. Backing plates are the same.
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 09-10-2009 at 06:10 PM. |
I bought a complete replacement rearend today.
Grandpa in the rustmobile...
I need to do this swap also..
is it just bolt in or do I need to readjust some kind of angle...pinion angle maybe? Do I just bolt a 71 72 rearend in...or is there some adjustintg?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
70 Chevrolet=Obsession
70 was the year that GM changed axle lengths. If your putting 71-72 axles on a 69 you should measure from the flange to the tip of the splines and get axles that are the same length.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
Watch out for your cornhole !
![]() Join Date: Jun 2003
You guys are making this harder than it is. Unbolt the 6 lug rearend and bolt the 5 lug rearend in place. Nothing fancy needed. It's an hour job.
i suggest getting new ubolts// local auto parts or spring store is where to get them
#8 | |
Thanks Kevin. I was pretty sure it was a direct bolt-in. I just wasn't sure about replacing the ubolts.
Hey 90/87 Formula.. I know this is a little off topic but does your name refer to the legendary Pontiac Firebird Formula? I had a 90 Formula 350 that I learned how to wrench on.
thats what i thought, just wanted to makesure, thanks TXfirefighter
Yep. The car started as a 90 coupe with the 3.1L MPFI. The 3.1 motor got trashed and I bought an 87 Formula rustbucket. I moved EVERYTHING that could be unbolted from the Formula to the coupe, thus 90/87Formula.
Robert Member 1532 Last edited by 90\87Formula; 09-13-2009 at 06:37 PM. |
