Old 09-13-2009, 05:26 PM   #1
57larry
6-V8 bellhousings the same?
I tried the search but came up empty. is a 6 cyl and a V8 bellhousing the same? can I used a 72 6 banger bellhousing on the back of my V8? thanks
57larry is offline   Reply With Quote
Old 09-13-2009, 05:33 PM   #2
BCOWANWHEELS
Re: 6-V8 bellhousings the same?
Yes same thing for all v8,s and 6,s
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-13-2009, 05:44 PM   #3
highperf4x4
x2
highperf4x4 is offline   Reply With Quote
Old 09-13-2009, 07:46 PM   #4
Shaky
Six in a row makes it go...
Shaky's Avatar
Be careful. Make sure it has the right diameter hole where the transmission pilots. The ones for the SM465 and the ones for the 3-speeds are different.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 09-13-2009, 07:49 PM   #5
57larry
I'm dumb, what the SM 465?
Old 09-13-2009, 08:52 PM   #6
clinebarger
A heavy duty cast iron 4 speed with a very low 1st gear i always called them granny gear 4speeds
clinebarger is offline   Reply With Quote
Old 09-13-2009, 08:56 PM   #7
Mike C
Mike C's Avatar
SM 465 was found in 68 and newer trucks. If you have a 67 with the SM420, it has the small hole same as the 3 speeds.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-13-2009, 09:06 PM   #8
69 longhorn
2nd that..... 67 & older bells will accept a car trans(m-20/21/22 Muncie, or the B-W T-10s). The early bell was 4.683(4 11/16"), the late bell was 5.126 (5 1/8") for the center hole. best of luck. Crazy Al
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 09-13-2009, 09:26 PM   #9
69 longhorn
Last edited by 69 longhorn; 09-13-2009 at 09:27 PM. Reason: didnt need 2 posts....
Old 09-14-2009, 01:29 AM   #10
BCOWANWHEELS
My 71 has a 3 speed manuel and its the same size pilot hole as sm465
Old 09-14-2009, 02:20 AM   #11
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
my 67 has a 4-spd with the super low 1st....is that normal?
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 09-14-2009, 05:47 AM   #12
Shaky
Shaky's Avatar
This.
Yes - all '67-'72 had "granny" 4-speeds as an option. In '67 it was the SM420 (small center hole), and '68-'72 it was the SM465 (large center hole).
Old 09-14-2009, 05:48 AM   #13
Shaky
Shaky's Avatar
After reading the above, I guess I was wrong - it depended on the year. 67-small, 68-72 large. Learn something everyday
Old 09-14-2009, 07:20 AM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Not all 67-72 granny 4 speeds were SM465s. Some trucks had NP435s. I have one.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-14-2009, 07:36 AM   #15
lilred67
lilred67's Avatar
lilred67 is offline   Reply With Quote
Old 09-14-2009, 10:08 AM   #16
BarryB
BarryB's Avatar
Before we get way off in left field. The OP asked if a six cylinder bell housing will bolt up to a V8. Yes it will, if he is using the same trans from the 6 cylinder then he won't have to worry about the diameter of the hole.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 09-14-2009, 06:31 PM   #17
highperf4x4
x2 but I'm not sure if he's inquiring about the entire tranny or just the bell housing. He should probably clarify.
Old 09-14-2009, 09:08 PM   #18
57larry
thanks for all the replys. I'm going to use a Muncie 4 speed with the 6 cyl bellhousing on the back of my 350
Old 09-14-2009, 10:53 PM   #19
oldcarfart
and it will work just fine, enjoy!
oldcarfart is offline   Reply With Quote
Old 09-15-2009, 12:29 AM   #20
69 longhorn
Originally Posted by lilred67 View Post
That depends on the yr.....68 up with a 3 spd has the large hole bell , same as a 4 spd truck crazy Al
