Blazer Body Mount Bolt Measurements
Not exactly hi-tech imagery but I had em out and it's always asked, so here ya go.
Re: Blazer Body Mount Bolt Measurements
...and position 5
New Member
Just a heads up for anyone replacing their mounts with poly instead of rubber. I just did this and only a few of the stock length bolts worked. The poly mounts will require longer than stock bolts in almost every position. I think I was able to only use 2 or 4 stock length bolts, I can't remember for sure.
#4 | |
Thanks for posting up what you've run into. Last edited by vtblazer; 09-16-2009 at 11:15 AM. |
Remaining parts to each position aside from the rubber body mounts.
...and position 5.
![]() Join Date: Jan 2007
where did you get the kit from?
EDIT - After Googling the PN#s looks like the LMC numbers... Last edited by lks dcvn; 09-16-2009 at 11:55 AM. |
Wide n'Low
Thanks! good info that always seems to be overlooked..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
Great stuff VT.
Moderators please post to FAQ section.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
The set I got from Tim is what I would consider to be "complete".
There are other vendors out there selling...lets just say "not so complete" sets. ![]() Talked with another blazer guy who just received one of those 'other' sets and it was missing these items: * the square washers for the core support * the 7/16 core support bolts * ALL 4 concentric washers * and both position #2 bolts were M.I.A. At a premium price too. ![]() |
What does the kit from Tim cost - I checked his site - but couldn't locate it in the product listings.
Thx for posting this (BTW) - ![]() |
You're making it too easy for rookies
![]() We had to bleed,sweat & cry to get that far ahead in replacing them. I probly made 5 different trips to the bolt store to do mine hahaha Just messin ~ Good for the community ![]() When are you gonna ship me your tube doors? Not being a "harcore" wheeler anymore you don't need um ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#13 | ||
The incomplete kit in the pic was over $200.00 though. Quote:
Yeah, newbs have it to easy now for sure and still they don't bother to look anything up. ![]() Sorry bud, tube doors went with the blue blazer. Want me to build a pair for ya? Last edited by vtblazer; 09-16-2009 at 06:02 PM. |
Bump incase some missed this and are wondering.
#15 |
Future TOTM Winner
I'm wondering why it isn't in the FAQ section?
![]() I replaced mine a couple years ago with a poly kit but I didn't get the concentric washers. Did I screw up? Why does it need the concentric washers? I have everything pretty torn apart at the moment, should I add them?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#16 | |
They say a picture is worth a thousand words. ![]() |
#17 |
Addicted user
Thanks for the great info!
Now... is the body mount kit the same for the 2wd and the 4x4 blazers?? I am having trouble finding a kit that says it is compatible with the 2wd blazer.. thanks |
#18 |
#19 |
Future TOTM Winner
So the answer is "Yes, I should get them" looks like it keeps the body from shifting from side to side. Thanks Kurt, as usual you have made me realize that I need something that I didn't even know existed.
#20 | |
...well I'll take that as a 'good' thing. ![]() The factory didn't use the washers but it seems like a good idea, can't hurt. |
#21 |
It (offset washer) basically acts to lock the carriage bolt to the floor so you can tighten them down without welding the head to the bed.
#22 |
VT what grade are those 3/8 bolts ?
#23 |
#24 |
Great reference!!! Funny, that I found this not even 10 minutes after I order my set from LMC???
#25 |
![]() Join Date: Dec 2004
Anyone know what the factory torque specs are on these??
