No reverse lights?
I recently bought a '79 1 ton with a 4 speed. The reverse lights do not work. If this was an auto, I'd guess there is a switch on the shifter or trans to turn them on. I have no idea with the manual. Where is the switch that turns them on?
Re: No reverse lights?
there should be 2 switches on your shifter base. neutral safety/reverse lights
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
on my 86 there was relays on the shifter assembly under the boot
what about if it was 3 on the column, then converted to the floor...is there a switch in the steering column I can get to?
On my '87 4-spd, the backup light switch is screwed into the side of the gearbox underneath the truck.
