Old 09-16-2009, 06:37 PM   #1
sealw98
my brakes?????????
I started off changing my rear brake shoes and I proceeded to bleed brakes, no brakes still, I checked front shoes just fine, so I changed the master cylinder got a nice brake pedal when truck is off drove it and could not stop, as far as I can tell the brake booster seems to work fine no air sounds and not a really stiff pedal.I have visually check for leaks nothing that I can see any help would be greatly appreciated thanks.
sealw98 is offline   Reply With Quote
Old 09-16-2009, 10:41 PM   #2
SCOTI
SCOTI's Avatar
Re: my brakes?????????
More details will be needed to accurately help. What did the pedal do when you experienced the "no brakes still" comment?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-16-2009, 11:04 PM   #3
sealw98
they were going down almost to the floor but it seemed as though none of the shoes were expanding out almost like no friction there.
Old 09-16-2009, 11:33 PM   #4
SCOTI
SCOTI's Avatar
Did you bleed the master cyl independently before installing it, connecting & bleeding the lines?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2009, 11:51 PM   #5
62LS1
62LS1's Avatar
It may sound crazy, but did you expand the shoes out to meet the drum after installing the new shoes?
Too many dreams, too little money.
62LS1 is offline   Reply With Quote
Old 09-17-2009, 12:20 AM   #6
sealw98
Yes we did bleed the master cylinder, but I will have to check and see if he (my father)adjusted the rear brakes.
